E Grimlins!!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-14-2013, 08:14 AM Thread Starter
E Grimlins!!!
The electrical Grimlins strike again. I have been away training for a job. My wife drove my truck while I was gone. Now it won't start. Key on all lights and gauges are active, ignition on and I get a single click and no turn over, nothing at all. All fuses have been checked and found good, Terminals are clean and it is all the way in park. The only thing I haven't checked are the relays. Not sure which one would have anything to do with starting. My book has come up missing during my absence. Any help from the pro's or shade tree trouble shooting experts would be great.
2000 F-250 7.3l diesel lariet 4x4.
michael.payne is offline
post #2 of 3 Old 04-14-2013, 08:31 AM
Quoted: 171 Post(s)
Feedback Score: 3 reviews
First, go get the OM -> https://www.fleet.ford.com/maintenan...ls/default.asp
Next, what you're describing sounds like the current the Starter requires isn't getting to it. The next observation you should make is what happens to those lights on the dash when you roll the key to start. Do they dim? You can also turn the Headlights on and watch them when you try to see if they dim.
If they do, the entire system is having trouble supplying the current (bad batteries - connections ANYWHERE in the cables, or the starter itself is asking too much because it's bad)
If they don't, the click you hear is likely to be from the starter solenoid (pass tire well under the hood) or the starters Bendix solenoid that throws-out the gear and mounted on top. Sometimes the starter itself has a bad connection inside where the brushes ride on the commutator.
The first, and easiest thing, to do would be to slide-under with a hammer and give the starter a few whacks. This often reseats the Bendix/Brushes and the starter will work. Carry a hammer with you and see if it fixes it a few times then I'd be thinking Starter.
Next, is the solenoid on the fender well. It has two sm wires going to it and two lg. It's job is to connect those large wires together when you turn the key (activated by the two sm ones) and send Big Power to the Starter. With 1/2 a jumper cable (just one side) you can jump those two big wires and bypass the solenoid. If it cranks-up fine (and the "click" you hear is coming from it) I'd be thinking it's bad...
NoRalPh is offline
post #3 of 3 Old 04-14-2013, 08:52 AM Thread Starter
Solenoid was the problem! Thanks for the help. Powerstroke.org is has saved the day again. This website is batting a 1000 for me so far. I have never had a problem with this truck that I couldn't get fixed with the recommendations of the good folks on this site. You saved me a lot of trouble shooting and I learned something today. Thanks again brother.
