  #11 (permalink)
Old 02-09-2008, 07:09 PM
99bigred 99bigred is offline
yep this site is the best....way to go guys
  #12 (permalink)
Old 02-09-2008, 07:10 PM
mschn99 mschn99 is offline
just remember....the site being awsome is a result of the people that post on it being great!!! Im proud to be a part of it and its EVERYONE that makes it what it is!!!
  #13 (permalink)
Old 02-11-2008, 07:23 AM
BigDaveZJ BigDaveZJ is offline
Been having the same issue with my truck.
My question is WHERE is the switch? A buddy of mine who used to have an F350 and is an ASE Tech told me it was at the front of the door, but in reading all of parts descriptions for a new switch, they keep saying the switch is part of the latch, which I would think is at the BACK of the door.
[/hijack]
  #14 (permalink)
Old 02-11-2008, 07:25 AM
[/hijack]
its inside the door in the latch....
u have to take the door panel off...then the three Torx 27 screws out of t he latch....the manuver the latch to twist the door switch out...which twists into the bottom of the latch...
  #15 (permalink)
Old 02-11-2008, 07:29 AM
Right, I'm not going to replace it yet though, going to try cleaning it first via this method:
Dome lights stay on
My question is, do I spray in the hole where the black rod goes from the a-pillar into the door, or on the actual latch mechanism where it attaches to the b-pillar?
Also, an easier solution to stop this from draining your batts is to just to pull the top-left relay in the box under the access panel under the dash. Mine's been that way for 6 months, just finally getting around to fixing it.
  #16 (permalink)
Old 02-11-2008, 07:34 AM
Triflex Triflex is offline
Just for kicks have you checked the light switch you put the headlights on with to see if its turned too far to the left?
  #17 (permalink)
Old 02-11-2008, 07:36 AM
Yup. Electrical stuff may not be my automotive strongpoint, but I did check that.
  #18 (permalink)
Old 02-11-2008, 09:44 AM
i sprayed it were the actually latch is
good luck
  #19 (permalink)
Old 02-11-2008, 10:47 AM
Got it fixed. The switch is definitely not where my buddy said it was. Switch wouldn't clean out, so grabbed a new one. For $15 it wasn't too bad. Shoulda fixed the door lock actuator while I was in there. Oh well.
  #20 (permalink)
Old 02-11-2008, 11:07 AM
6.0 paul 6.0 paul is offline
My excursion has this problem all the time. I just spray w/ wd40 every spring & fall. This seems to help out
