  #11 (permalink)
Old 03-03-2008, 06:21 PM
idrinkdiesel idrinkdiesel is offline
Yes I did find out. I meant to post the news. Well here is the low down. Someone got in the bearing and hub assembly and totally screwed it up. Nothing was reinstalled properly so the right front bearing, hub and axle had to be replaced. They checked the left side too. It was not assemble right either. They fixed it and no damage done to the left side.
When I kicked it into 4 wheel high the vibration went away but there was still damage being done. Total cost $1700
Hope that helps buddy.
  #12 (permalink)
Old 03-03-2008, 06:24 PM
Diesel Monkey Diesel Monkey is offline
Check if the bolts that connect the transfer case to the trans are tight.
