Old 02-09-2008, 10:08 AM
AggieExcursion2010 AggieExcursion2010 is offline
Shim affect smoke?
does the FPR shim / BB affect how much smoke is produced if any?
Old 02-09-2008, 10:10 AM
SMKSTAX SMKSTAX is offline
KCR DIRECTOR
Didn't change anything as far as smoke on my 97.
KOOOPSD KOOOPSD is offline
Send a message via AIM to KOOOPSD
I'm also interested in this.
Tikal Tikal is offline
Thas how we do'r in Dixie
Send a message via AIM to Tikal
Not that I'm aware of. It just gives you better fuel pressure resulting in a smoother idle. More oil going to injectors = smoke
Old 02-09-2008, 10:12 AM
mschn99 mschn99 is offline
Shouldnt....
on a side note....dont just shim it without checking actual fuel pressure....too much pressure is a bad thing too.....
Old 02-09-2008, 10:14 AM
najaf4life najaf4life is offline
Look Ma.. No Hands
well Marc then what is the real addvantage to shimming the FPR?
Old 02-09-2008, 10:39 AM
craig long craig long is offline
i have the 1/8" fittings, the bb and the 200 psi guage and am in the garage ready to install. i have lost the video and don't know where at the fuel filter housing it is installed. call me 913-620-3288.
is it where the fuel line goes in at the driver's side of the fuel filter housing?
Old 02-09-2008, 10:57 AM
if you bump it up just a bit it will improve idle and throttle responce.....bump it up too much and you will take your fuel pump out though...
Old 02-09-2008, 11:03 AM
Look Ma.. No Hands
okay that is what I heard but I have heard that if you bump it up to 73 to 75 you should still be fine... and Marc and glad to see you on here more often now... I have been a member for a while and haven't really ever seen you on here or talked to you before
Old 02-09-2008, 11:29 AM
you are correct....and thanks buddy!!!
