  #11 (permalink)
Old 02-10-2008, 05:21 PM
mels mels is offline
Originally Posted by Maintain View Post
...If you get any snow... I'd seriously reconsider a locker when thinking about a DD and especially if you plan on towing.
Thanks for a little more insight, Maintain.
Am I to understand then you advise against the Detroit locker for towing, and in snow? Just want to clarify.
I dropped a 12 bolt posi in an Olds Cutlass I'd also found a 455 for 100 lives ago, and that damn thing'd spin right around inside of itself on me if the wheel was at all turned when I punched it.
I do remember it being good in the snow as long as I kept weight in the trunk and my foot well out of it though. Air-shocks kept the ride height level or a little higher in the back. I seem to remember a couple hundred pounds of sandbags back there during the winter.
The tires, outside of Winter, never seemed to last long enough to develop a strange wear pattern - for some reason...
My van has waaay too much weight in it. A 1 ton, the only thing keeping it from dragging its' nuts on the ground are the "Air-Lift" air bags I installed at each corner.
I'm absolutely sure the weight (and distribution thereof) is the only reason I haven't had any trouble getting through the snow, yet.
Is the true track really the better unit for me? Serious question, which is why I started this thread, I value all the experience and opinions of everyone here.
Thanks again, Maintain, and everyone else
  #12 (permalink)
Old 02-10-2008, 05:28 PM
Marty Marty is offline
International Threat
Well the tire issue may have something to do with the short wheel base of the veh's I'm associated with.
If you have BOTH wheels on the ground with a true-trac you will have posi traction while the torque is applied. The moment you LIFT a wheel all bets are off. In your van, I highly doubt you'll do that LOL...
I guess if I was you... I'd get the true-trac. If you lived in Florida I'd maybe spring for the locker.
Also - in case you've never heard of "crab walking" try googling it. When you're towing in the snow/slick road you're more likely to loose traction with both wheels spinning and slide sideways.
  #13 (permalink)
Old 02-13-2008, 05:27 PM
Thanks again for the input, Maintain.
I wonder what, if any, other items I should replace while I'm in there?
