140hp tune on stock truck. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-12-2013, 11:12 AM Thread Starter
I'm gonna be grabbing up a 6pos tuner from KTperformance. I do take my truck to the track every once in a while and am trying to decide what tunes i should include for track days. My truck is a 99, only mods are air intake and mbrp 4 inch exhaust. Would my truck benfiet from the 120 or 140hp race settings, or would i need upgraded injectors and fuel pump to utilize it. I read that a stock truck runs best on the 80hp tunes and gets bogged down with the higher tunes, any truth to this? I have an edge evo right now and my truck runs solid with the 100hp setting.
thrashin302 is offline
post #2 of 7 Old 04-12-2013, 11:15 AM Thread Starter
also. i have a replacement engine in my truck i got from a ford dealership, its got about 15k on it now, but im guessing its got PMR's, would it be safe to run the 140hp setting on it.
post #3 of 7 Old 04-12-2013, 11:30 AM
blue99stroker's Avatar
Quoted: 283 Post(s)
ya with good tunes you will notice a difference.
a few tuners wont sell you the 140hp setting cause of your pmr motor but most will.
but you would be fine cause you will be far under 400hp.
their is a big difference between edge products and a custom tuned chip.
so yes you will notifce a difference from 100hp to 120-140hp tunes.
oh and i hope you have gauges too!
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #4 of 7 Old 04-12-2013, 11:35 AM
HogginNboggin9's Avatar
IMO when i had my 7.3 i had a dp tuner and it actually ran better on the 120 setting vs 140, but i also had stock hpop and stock injectors. And no you do not need upgraded injectors or hpop to run the higher hp settings, you would just be getting the full benefit out of the 140 setting if you did.
Also suggest getting a set of guages, egt,boost and trans.
egt being most important boost just for fun and trans if ur towing heavy....
And do you kno what year truck ur motor came out of ?, 99-late 2000 all had forged rods but besides that point,yes you will be fine weather its forged or pmrs, pmrs are good for at least 450-500 hp but like i said above you will not see the full benefit of the 140hp setting because of the fact that ur still on stock injectors and hpop.
HogginNboggin9 is offline
post #5 of 7 Old 04-12-2013, 10:35 PM Thread Starter
So the engine would be safe with a 140hp tune as long as im not pushin 400hp? The engine was a new crate engine i got from ford 2 years ago, i'm not sure if it has pmr's or not but i'm assuming id does. I plan on leaving my edge hooked up just for the gauges and high idle.
post #6 of 7 Old 04-13-2013, 07:12 AM
yes the engine would be safe either way, weather ur pushing 400 or not imo i wouldnt worry about pmrs until the 450 range but you would be nowhere near 450 or 400
-04 f250 6 leaker
Skyjacker 4 inch lift,MBRP 5in Straight Pipe,03 turbo,ipr gen 2 egr delete,sinister coolant filter,blue spring mod, autometer gs guages pyro,boost,fuel psi,scanguage2, SCTx3 tunes from idp,no studs yet.
-96 f150 5.0
Superlift 8 inch lift,SAS 8 lug conversion,38.5 boggers,Mazda 5 speed stick shift swap from auto.
-HAD a 2000 7.3 dp-tuner,ATS Housing,leveling kit, MBRP 4in Straight Pipe,guages pyro,boost,trans temp,Stancor Mod,napa 6637. Traded it for my 6.0
post #7 of 7 Old 04-13-2013, 02:14 PM
Quoted: 283 Post(s)
you will be fine
ya i would just use the edge for gauges, im guessing you have the cts with a monitor or something like that.
