Factory turbo housing - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-12-2013, 09:12 AM Thread Starter
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 15 Post(s)
I just pulled out my turbo to install bellowed up-pipes and noticed my housing said 1.0 A/R where the outlet meets the spyder. Is that normal or did the PO upgrade it.
Thanks
410,000 miles
PHP Hydra Mishimoto Radiator
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #2 of 5 Old 04-12-2013, 09:33 AM
timmyboy76's Avatar
nope, completely stock. 1.0 intake side, .84 exhaust side
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 5 Old 04-17-2013, 12:06 PM
tubular031's Avatar
if you still got it apart, go get one of the 1.0 exhaust housings. I really like mine.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #4 of 5 Old 04-17-2013, 03:17 PM
Do you really notice a difference with the 1.0 exhaust? Also, when swapping out turbo's (just stock), is it a good idea to replace the pedestal also?
hemloc is offline
post #5 of 5 Old 04-18-2013, 12:41 PM
tubular031's Avatar
Down low no difference. where you feel it is when you are at 45 in 3rd or 65 in od and you drop the hammer. it pulls more. before the 1.0 exhaust it did not feel like it wanted to go at those same speeds. Have not yet got to pull a load to see how it works out for me. But then again its been so long since I have pulled a load who knows if I will feel anything different.
