Old 02-08-2008, 06:00 AM
Tex99F-250 Tex99F-250 is offline
Installed programer
I barrowed a superchip flash pack tuner.It make a big diffrence on the power,but i dont like the way it makes it hold the shift. i had a ?. when i get on it it sounds like it got an igniton ping. is this common or should i look for something.
Btw im giving it back and getting a dp.
Old 02-08-2008, 06:31 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Give me some info on your truck like what year.
I experienced similar problems with both the superchips downloader and a diablo sport chip. The early99's seemed to really have a problem with the generic tuning and even to some extent the custom tunes as well.
Old 02-08-2008, 10:21 AM
Its an early 99. has 236,000 mi. the only thing i have done to it is a 4in turbo back and diy intake.
on the 1-2 shift it seems like it take too long.
Im planning on an aftermrket valve body. Was also looking at a pan by DERALE with the cooling tubes through it. Then go with the dp tuner.
Do you think the dp will fix my pinging problem. what do you think is causing the sound. Thanks for the info.
Old 02-08-2008, 10:23 AM
REDPOWERSMOKER REDPOWERSMOKER is offline
WE ARE DOOMED
Tournaments Won: 1
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
DOES THIS COUNT WITH THE GENERIC TUNES FOR A TS CHIP????
Old 02-08-2008, 02:53 PM
With that many miles I would pull the injectors and put new O rings in. My truck was making that noise and it ended up being 3 bad injector O rings. The DP tunes made the noise worse than what it sounded like the TW tunes.
The DP tunes will help the shifting. Jody did quite a bit of tuning work on my truck to get the trans to work very nice. Keep in mind of you run a chip/tuner of any kind you need gauges to keep an eye on things. And if you get a John Wood Valve body, Jody and John work very closely together and it makes a nice combo.
Keep Strokin'
PS, there is some good info in the early99 section.
Old 02-08-2008, 04:47 PM
Are the o rings special or just a standard oring out of a kit. if special where is the best place to get them.
also would it hurt to run it like that. wanted to make a pass or two down the track before i gave it back.
thanks for the info.
Old 02-08-2008, 05:15 PM
Where the best place to a jw valve body. Directly from him
Old 02-08-2008, 10:05 PM
Either from him or from Dennis at ITP diesel.
John Wood Automotive - Home
ITP Diesel, L.L.C.
Old 02-08-2008, 10:24 PM
The O rings are available here: Motorcraft 8-sets of Brand New 7.3L Ford Powerstroke Diesel Injector O-ring kits
Or on Fleebay here: eBay Motors: Powerstroke injector o-ring oring seal installation kit (item 320101389774 end time Mar-02-08 11:16:09 PST)
I would not worry too much about hurting it if you want to make a few runs down the track. I ran my truck down the drag strip 11 times, sled pulls and towing for 20K miles. If you turn it to a lower tune, does it still do the same thing?
Old 02-09-2008, 09:01 AM
I put it on perf tow and it did the same thing. it only seems to do it in lower gears (1 & 2)when it rpms quick. If your crusing down the road and stand on it it wont do it.
When i pull the injector is there a drain plug for the oil & fuel. I was told how to do it a while back and forgot. hands on helps the brain.
