Gillete fuel pressure spring - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-11-2013, 06:17 PM Thread Starter
early99psd's Avatar
Quoted: 12 Post(s)
So I bought one of these springs and put it in then ended up taking it out. Because it sounded like my fuel pump was working harder. I now have a riffraff FPX lines. Is any one using one of these. I have not checked my fuel pressure so I don't know where it's at. Is there a cheaper way to check it other than buying the gauge set up. Should I put it in and run it without checking where my fuel pressure is?
Sent from AutoGuide.com App
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #2 of 4 Old 04-11-2013, 06:23 PM
timmyboy76's Avatar
you can rig up an el cheapo to give an idea wherethe f/p is.
200psi liquid filled gauge from Harbor freight (5 buks)
18" grease gun flexible hose (3 buks)
Now, you gotta go to a hydraulic store and ask for a #4orb(male) X 1/8npt(female)
Not only will it check f/p, but you can mount it to the allen plug on top of the hpop resivoir and check oil psi..
The #4orb, will thread into the fuel bowl. There's 2-ports with plugs in them. The pass side is post filter, seeing psi what the injectors sees, driv side is pre-filter...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 4 Old 04-11-2013, 06:25 PM
timmyboy76's Avatar
attach photo of fuelbowl, locating the ports.
Name:	Fuel Filter with labels.jpg
post #4 of 4 Old 04-11-2013, 06:39 PM Thread Starter
early99psd's Avatar
Quoted: 12 Post(s)
Thanks that sounds better than spending 200 on a gauge set up for now. Then I can figure out which spring I need. If I need one at all.
