2001 F350 headlight and parking light update - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-11-2013, 08:57 AM Thread Starter
Good morning everyone. I'm new here and just bought a 2001 F350. I would like to put some 2002-2004 headlights and parking lights on it to update the look along with the 05-07 grille. Do these headlights bolt right in with no modification? Thank you kindly.
celltech is offline
post #2 of 10 Old 04-11-2013, 09:39 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Welcome to the forum!! I'm pretty sure they will just bolt right up, but not 100%.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #3 of 10 Old 04-11-2013, 10:27 AM
They will 100% bolt right in - it is the best thing I've done to both my Super Dutys thus far. I drive A LOT at night and the output is so much better.
Rockauto.com - the TYC lights for roughly $60 shipped/pair are the way to go. They come with new bulbs in them even. The top two adjusters I use and then unthread the bottom to get the old lights out - then take them off the new lights and use the old adjusters down low. It took me maybe 15 minutes to put both headlights in either pickup.
The little metal clips that hold the lights in can be a Pain in the *** - use needle nose pliers and a flat head screw driver to sort of pop them out - you'll see when you look at it.
Good luck! You'll be amazed at how much better the lighting is!
2001 CCLB SRW 6spd - 375K and counting
2003 GMC Yukon - Her baby Hauler
1992 Acura NSX
1997 Honda Civic Hatchback - 2.4 liter, 6266 Turbo
ProOnThaSnow is offline
post #4 of 10 Old 04-11-2013, 10:45 AM Thread Starter
Thank you very much.
celltech is offline
post #5 of 10 Old 04-11-2013, 11:48 AM
And an added benefit is that it doesn't make the truck look so "grungy" it adds a much cleaner look up front, especially with an 05 grill (like I have on my '01). Add the bumper too and it looks like a completely different truck!
1992 Acura NSX
post #6 of 10 Old 04-11-2013, 01:03 PM
timmyboy76's Avatar
if you go the 05 grille route, and keeping your 99-04 bumper, cut 3/8in off the bottom of it. Fits perfect then.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 10 Old 04-11-2013, 04:22 PM
I didn't change the corner/marker lights on either of my trucks. I prefer the amber ones over the clear personally.
1992 Acura NSX
post #8 of 10 Old 04-11-2013, 05:19 PM
early99psd's Avatar
Quoted: 14 Post(s)
How is the light pattern on the rock auto headlights? I bought some cheap ones on eBay and they suck!
Sent from AutoGuide.com App
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #9 of 10 Old 04-11-2013, 05:37 PM
These are made by TYC and they have a good pattern to them - I drive, like I said previously, all hours of the night for work in the oil field (I go when they call). I do have them adjusted a tad high, but I want to see whats ahead as much time as I spend on the road - up to 6,000 mi/mo.
When I bought my 2000, the headlights were the very first thing I ordered for them.
1992 Acura NSX
post #10 of 10 Old 04-11-2013, 06:52 PM Thread Starter
I ordered the headlight assembly's from rock auto and found the 02-04 style parking/turn signal assembly's from partsgeek. I also ordered the chrome 05-07 grill from MKM Customs. Thanks again for the help guys.
celltech is offline
