Shop says I need a new PCM and IDM due to tranny swap - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-11-2013, 09:49 AM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Ok so i took my truck to the shop to have the GP"S and injectors check well they call me and said that its throwing all kinda codes and said its due to it being swapped to a 6 speed. They said that its showing bad IDM (which i just replaced 2yrs ago) due to having the wrong PCM i guessing from when it was an automatic. I told them that when im going up a slight incline and have to give it alittle more peddle that the CEL with blink here and there but seems to run ok. What do you guys think. Could i just have someone flash/reprogram my pcm?
1999 Ford F-250 Crew Cab Lariat 4x4 7.3L Powerstroke zf 6-speed Planet colors Amber White Pearl
banks big head wastegate, edge ez module
snow performance, 4" stright pipe,6637 FILTER MOD southbend stage 2 clutch, 05' front end upgrade
8" procomp 37" M16 Swampers 18x9 xd monsters, MOOG everything BILSTEIN SHOCKS BILSTEIN DUAL STEERING STABILIZER COOLANT FILTRATION, 203 stat 08' mirrors
bck4more is offline
post #2 of 6 Old 04-11-2013, 09:56 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Find another shop...
First, there's no such thing as a "Manual or Auto" IDM.
The PCM IS different, there is of course, no need of the Trans control your PCM is still doing. BUT, First find out what the code is the PCM is setting (if you've seen a CEL) because I'd think anything that PCM was unhappy about, Trans Wise, would result in the "blinking" the OD light.
I honestly don't know what happens if you run an Auto PCM in a Manual Truck,,, but it wouldn't make my first move be to buy another one trying to cure " when im going up a slight incline and have to give it a little more peddle"
LOTS of people have done the Trans Swap, I'm sure somebody with more experience than me will give you the right answer...
NoRalPh is offline
post #3 of 6 Old 04-11-2013, 10:01 AM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Thanks NoRalPh for the quick reply. I sure hope its just a matter of getting it reflashed or something else.
bck4more is offline
post #4 of 6 Old 04-11-2013, 11:56 AM
blue99stroker's Avatar
Quoted: 243 Post(s)
i think you can send it in to different vendors who would flash a manual tune on your pcm
then just do the same to your chip if you have one they can reburn
i think dp tuner still flashes pcms
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #5 of 6 Old 04-12-2013, 12:44 PM
When I did my conversion I ran with the auto PCM for a little while. Basically out would hiccup under certain load conditions and occasionally flash the check engine light. You should see about getting it reflashed or get a manual PCM. The IDM shouldn't matter
Matthews is offline
post #6 of 6 Old 04-12-2013, 12:49 PM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Thanks for the input guys. Yeah so im gonna pull it and send to DP tuner to have it flashed for a manual maybe even have them put a tune on it also since they only charge like an extra $10 or something like that.
bck4more is offline
