Steering/front end problems - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-10-2013, 05:34 PM Thread Starter
New rotors, pads, and calipers about 5000 miles ago/9 or 10 months ago on front, also new shocks and steering stabilizers at same time. Truck was good, drove strait, didnt pull when braking or driving until about 3 weeks ago. Now the driverside brakes are squeeking bad, plenty of pad left. It pulls bad under braking and in different directions sometimes pulls right sometimes left. Under normal driving it pulls left.
What the hell??
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #2 of 12 Old 04-10-2013, 07:24 PM Thread Starter
Can anyone give me symtoms of sway bar bushing failure, or drag link slop/bad?
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #3 of 12 Old 04-10-2013, 07:27 PM
michaelbyoung's Avatar
Sometimes the brake caliper pins freeze up and don't move right.
Sent from AutoGuide.com App
2006 F-350 Lariat Crew Cab Long Bed 6.0 Diesel
Chrome Pkg All Stock 185,000 miles
B&W Turnover Gooseneck w/ 5th wheel companion
ScanguageII High idle mod On board air
2011 Jumpseat Gutted Cat Mikeymod muffler
EGR delete CCV mod EC1 coolant Zoodad mod
2000 F-250 Lariat Crew Cab Short Bed 7.3 Diesel ***STOLEN*** 11/19/2011
4" Rancho Lift
215,000 miles
afe intake
4"turbo-back
IAH delete
Foil Delete
michaelbyoung is offline
post #4 of 12 Old 04-10-2013, 07:30 PM Thread Starter
Thanks Ill check them, new calipers but I live in a very salty enviroment so anythg is possible.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #5 of 12 Old 04-10-2013, 07:34 PM
cowens726's Avatar
X2 on the caliper slide pins, for whatever reason very common problem with these trucks. I chased froze up slide pins on all for corners of my truck about a year ago with similar symptoms, now I pull the calipers and grease the pins every other oil change. I know my sway bar bushings are bad but I haven't had any handling issues because of it other than clunking when I hit a bump.
cowens726 is offline
post #6 of 12 Old 04-10-2013, 07:39 PM Thread Starter
So I guess the pin dragging or freezing up could cause the pull to either side while driving(not braking) and cause the driverside to make noise?
Thanks a ton for the info guys.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #7 of 12 Old 04-10-2013, 07:50 PM Thread Starter
White lithium the best to use.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #8 of 12 Old 04-12-2013, 12:30 PM
rocktamer's Avatar
Yeap that works, they also make a special "caliper pin lube" but its more or less the same stuff. Make sure you get the boots resealed or the pin will rust pretty quickly (especially in the winter) and can be a PITA
1999 F250 XLT 4X4
rocktamer is offline
post #9 of 12 Old 04-12-2013, 02:30 PM Thread Starter
Well took calipers off today, cleaned the pins and greased them. I used high temp baring grease. Problem fixed.
Thanks for everyones help.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #10 of 12 Old 04-17-2013, 03:02 PM Thread Starter
Update, here it is 5 days later and the problem has resurfaced. Not sure what to do now.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
