Where do I look? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-10-2013, 03:07 PM Thread Starter
SuperCrutyPS's Avatar
Quoted: 296 Post(s)
Garage
Where do I look?
See my Sig.
Lately (last month or so) sometimes at idle, I have a hard time steering. It seems like the steering wheel starts to turn easily, but suddenly gets hard to turn. If I rev the engine a bit, it's easy to turn again.
Yesterday, I was towing my 5th wheel (~10K) back to my house. As I approached the house, I applied the brakes, but they seemed a little mushy and as I started to turn into the house, the steering was hard to turn. I eased up on the brakes slightly and the steering got easier.
Rolling along at speed, whether towing or not, I have no steering issues. And the 'at idle' problem doesn't happen every time.
I'm figuring it's something with the Hydroboost/power steering, but I don't know enough about it to know what to do next. I replaced the PS Pump a couple of years ago. Pump is full.
I kind of want to get this figured out before too long. Ideas?
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #2 of 14 Old 04-10-2013, 03:59 PM
Quoted: 28 Post(s)
Have you flushed the fluid ever? It made a world of difference in mine.
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #3 of 14 Old 04-10-2013, 04:06 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Agreed try giving the fluid a flush, but ultimately these pumps. especially replacement ones are known for this.
I've got a cheap reman in mine with 37's and so far it's okay, but I don't expect it to last long.
schlutzer is offline
post #4 of 14 Old 04-10-2013, 04:31 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Fluid flush will help some for awhile, But will probably need a new pump!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 14 Old 04-10-2013, 09:26 PM Thread Starter
Quoted: 296 Post(s)
Garage
Thanks for the input. I believe in doing the easy first. So...as soon as I get a chance, I'll flush it out. Any particular way to do that? I seem to remember a video or something showing 'how-to' - I'll have to research it.
I replaced the pump before, I can do it again. Not my favorite thing to do, but..........
My Truck Garage:
Tow Toy Garage :
post #6 of 14 Old 04-11-2013, 05:30 AM
Quoted: 28 Post(s)
Good ol YouTube
YouTube.
06 350 CCLB
Edge CTS
ARP's
Coolant filter
rentstdi is offline
post #7 of 14 Old 04-11-2013, 08:32 AM
Greenman01 is offline
post #8 of 14 Old 04-11-2013, 01:11 PM Thread Starter
Quoted: 296 Post(s)
Garage
Thanks for the links! That's pretty simple when ya know "where" to go. Looks more time consuming than hard. I'm glad the guy in the video mentioned the hose that gets removed. I'l have to figure out what to do with that so I don't make a mess....
My Truck Garage:
Tow Toy Garage :
post #9 of 14 Old 04-11-2013, 01:28 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I noticed after I did the flush on mine that for a bit the break pedal had a bounce to it when I first tapped it but it seems to have gone away.
I did the flush with some cheap fluid and figure Ill give it till June 1st or so flush again and run the spendy stuff...
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 14 Old 04-12-2013, 01:26 PM
rocktamer's Avatar
It a real quick and easy flush. Maybe 30 minutes tops. I cut a 5 gallon buck down and set it on my battery and extended the return line, piece of cake. Just make sure you do not let it run dry, I found pumping the brakes spit out a lot more fluid that turning the steering wheel, but make sure you do both.
1999 F250 XLT 4X4
rocktamer is offline
