2000 F350 No Trailer Brake/Turn lights. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-09-2013, 05:29 PM Thread Starter
Underpowered's Avatar
towed a trailer for the first time since i got my power stroke and noticed I have Running lights, but no Brake/turn signals.
I checked both under hood fuses (7.5 amp) and both Ohmed out good. with the ignition on, both has 12v to them.
all wiring connections looked good at the plug end. By myself it was hard to to check for voltage at the plug itself however. My old meter does not react fast enough to check turn signal voltage changes. Gonna bring my meter home from work tomorrow to try again, but best i can tell it is not getting voltage to the plug.
My main concern however is if my brake contoler is working as i plan on towing about 12k this weekend and NEED it working, and plan on checking it as soon as i have some help to do so. I check wiring at the controller and i get voltage to it, and out of it, but once again can't check at the plug alone.
But as for the lights, i am stumped, without tracing individual wires back, i am not sure. are there any other relays/fuses specifically for the trailer setup?
'89 K5 Trail Rig--not at all stock
'98 Jeep ZJ DD-nearly stock
'00 F350 Tow Pig- bone stock.
Underpowered is offline
post #2 of 2 Old 04-10-2013, 05:56 PM
Joel's Avatar
Quoted: 10 Post(s)
Bump for this fellow.
I had the same problem last time i pulled a car, weird this is that it worked perfectly a few months before that.
Havent had time to check for myself yet.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
