overhead display - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-09-2013, 12:56 PM Thread Starter
overhead display
I was just curious in how accurate the overhead display is in these trucks. The only thing that has not ever changed since i bought it is the mpg calculation. The miles to e and the temp moves but just wondering how if it was worth anything.
Squeaks is offline
post #2 of 3 Old 04-09-2013, 03:25 PM
Just so you know if you hold both buttons down it resets the mpg.
brookshirej2 is offline
post #3 of 3 Old 04-10-2013, 11:09 AM
early99psd's Avatar
Quoted: 13 Post(s)
With mine chipped it is way off, it reads 29 mpg. I don't think they are that accurate. I always check mpg 's against the pump. With mpg 's being off the miles to empty is way off as well. Compass and temp work fine.
Sent from AutoGuide.com App
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
