Old 02-06-2008, 05:05 AM
jnhuber jnhuber is offline
Axle?????
What is a good axle to replace my front axle with. I currently have a Dana 50
Old 02-06-2008, 05:09 AM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
Dana 60 would be the best option.
Old 02-06-2008, 05:10 AM
thbd77 thbd77 is offline
Dana 60 I belive the only differance is the dana 60 has a bigger ring gear
Old 02-06-2008, 05:18 AM
RRonning1984 RRonning1984 is online now
Heavy Equipment 911
Is the front axel out of an F350 a direct bolt in swap for the F250? I have been wanting to do this my self.
Old 02-06-2008, 05:30 AM
yea but on the superduty dana 60 are only dually version you will need to change out the hubs to srw.......on obs there were srw f350 with a dana 60
Old 02-06-2008, 05:44 AM
MINI-MOD
On the OBS trucks, you do not have to change the hubs. You just remove the wheel spacer and put studs in the rotor. I think SD's are the same, but not positive.
Old 02-06-2008, 06:00 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
i have a SRW truck with a dana 60 front end... i forget what year they started putting dana 60's in all SRW applications....
Old 02-06-2008, 06:03 AM
MINI-MOD
I remember seeing that info some where, let me look.
Old 02-06-2008, 06:07 AM
odieub odieub is offline
i think it was 02 03 along that time frame
Old 02-06-2008, 06:11 AM
MINI-MOD
That's what I was thinking. The excursions kept the dana 50's though.
