manual 4x4 in 99 7.3L powerstroke - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-05-2008, 04:56 PM Thread Starter
does anyone know if you can leave the hubs locked in but not have it in 4x4,in other words can you drive as normal in 2 wheel drive with the hubs locked in(manual 4x4) ,but they don't actually lock in untill you shift the stick into 4x4 high or low?if you can do this is it wise?i just get so sick of having to get out to lock it in every time i need 4x4,it's bad enough having to pull over and stop to change the gears manually,oh if only i had one of those buttons to push,lol.thanks in advance for any replies.
dansford is offline
post #2 of 9 Old 02-05-2008, 06:21 PM
99bigred's Avatar
it wont hurt anything but gas milage as long as you didnt leave it in all the time. Do you want to leave it on all the time or just while wheeling or snow driving?
early 99 f-350 7.3 6speed crew cab
banks exhaust, chip, big head, exhaust houseing
and wheel
Ford AIS intake
5.5" fabtech lift w/ 35x12.50/18's
99bigred is offline
post #3 of 9 Old 02-05-2008, 06:25 PM
lrazer's Avatar
if you leave the hubs locked you'll just be spinning the axle shafts, diff and driveshaft so that just = less fuel economy, more wear on components, and more vibration but it wont really hurt anything
15 F350 RC 4x4
14 F550 CC 4x4
05 2500HD CCSB 4x4 Duramax
02 F250 CCSB 4x4 ZF6 Swap
- aFe Stage II, 4" TB Exhaust, P.I.S. 160cc/30%, GTP38R, T500, DP-Tuned
- ITP Overboost Annihilator, Regulated Return
02 F250 CCLB 4x4 (Parting Out)
02 F250 SCSB 4x4
- Ford AIS Intake, 4" TB Exhaust
- ITP Overboost Annihilator, DP-Tuned
01 F250 SCLB 4x4
- DIY Intake 4" TB Exhaust
99 F550 RC 2x4 ZF6
lrazer is offline
post #4 of 9 Old 02-05-2008, 06:26 PM
todd's Avatar
on the diesels it really doesnt hurt milage that much but its gonna cause a bit more wear to seals and bearings and such but no it wont hurt anything i away leave mine locked thru the winter months
traded it for an 06 dodge sorry
todd is offline
post #5 of 9 Old 02-05-2008, 06:26 PM
CSIPSD's Avatar
I drive all winter that way... Not going to hurt a thing. Manual T case is the only way to go...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 9 Old 02-07-2008, 04:49 PM Thread Starter
in reply to 99BIGRED,would like to leave it locked in all winter but only use it when need to 4x4 or snow driving,just get sick of having to get out and lock it in when i need it through winter.
dansford is offline
post #7 of 9 Old 02-07-2008, 04:55 PM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
leave them locked. I lock mine in and leave it when i start runnin the haul road regular but stay in 2WD till it wont go any more. i also like to lock it in for a few weeks off and on in the summer so i can get it lubed up once in a while.
when i am running the haul road i put on about 750-1000 miles a day sometimes two weeks straight so i get miles on with hubs locked and no problems in my diff or Tcase. hope this helps
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
post #8 of 9 Old 02-07-2008, 06:48 PM
99bigred's Avatar
shouldnt hurt anything but if your not gonna be using it for awhile no reason to leave them locked, just extra wear on parts
and wheel
Ford AIS intake
99bigred is offline
post #9 of 9 Old 02-07-2008, 09:38 PM
The route I take to school leads me through some usually cruddy roads, so I leave em locked. However, I head to work after that which leads me to a 20 mile freeway run, by all rights it should not hurt the components too much. I am hesitant to run at those speeds with them locked though, and be in 2 wheel drive. I agree though it is a pain to get out and unlock them. I supposedly have auto locking/manual hubs, but it never seems like they lock up in the auto position.
Tastardan is offline
