Need help from the autobody painters - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-05-2008, 02:54 PM Thread Starter
Black Pwrstroke's Avatar
Ok so im just startin out painting and im gana try and fix my girlfriends front bumper on her car where she ran into a pole and the paint off the pole is now on the bumper. I know i have to buff the paint off but do i have to reprimer it and after i get it painted back to silver, how many clearcoats do i need to put over it? Oh and what kind should i use? Thanks guys
24v that drinks like a 12v
Black Pwrstroke is offline
post #2 of 5 Old 02-05-2008, 02:58 PM
rankroddin250's Avatar
before you try any thing get a rag and some acetone. I know it worked when i ran my half ton into a green steel gate. if it works once you get the paint from the pole whiped off then use soap and water to wash the acetone off so it doesnt eat the paint on the car.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #3 of 5 Old 02-05-2008, 02:59 PM Thread Starter
ok il try that first, but just for advice how would i do it if i needed to repaint it?
post #4 of 5 Old 02-05-2008, 03:08 PM
I havent done much painting. hopefully some one else can come along and help. I know on a good paint job you compleatly sand the old paint off. then aply one layer of primer then it has 2 good coats paint, then wet sand it, cut and buff, then wash and hand dry, then clear coat, then a cut and buff on the clear coat with a good hand wash and wax...
depending on the car if you can lay the paint right just a good smooth coat of paint would probly be fine for the bumper. what kind of car does your g/f have?
post #5 of 5 Old 02-06-2008, 12:29 PM
fishingjred73's Avatar
if its a plastic bumper you have to add a flex agent so when the bumper moves the paint doesn't pop off
02 F-350 srw cc
DIY tymar intake
08 bed mod
fishingjred73 is offline
