Accronyms list? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-06-2013, 09:35 PM Thread Starter
Lunnzz's Avatar
Accronyms list?
This might sound stupid but I am new to diesels and have been reading a bunch here and have seen a ton of accronyms. Some that I have seen are CPS, CCT, IPR, EBP etc. I am just wanting to learn as much as I can thats all.
Thanks
2001 F-250 Superduty
Edge programmer
AirRaid intake
4" open exhaust
6" lift
37x13.50x18 Toyo mud terrians
Lunnzz is offline
post #2 of 9 Old 04-07-2013, 06:02 AM
mcyrana's Avatar
This is a few of what international uses for their engines
IAT= Intake Air Temperature
IAHC= Inlet Air Heater Control
ABS= Antilock Brake System
IAHD= Inlet Air Heater Diagnostic
AC= Alternating Current
IAHR= Inlet Air heater Relay
A/C= Air Conditioner
IC= Integrated Circuit
ICP= Injector Control Pressure
IDM= Injector Drive Module
IGN= Ignition
AIT= Air Intake Temperature
inHg= Inch of mercury
INJ= Injector
IPR= Injection Pressure Regulator
APS= Accelerator Position Sensor
APS/IVS= Accelerator Position Sensor / Idle Validation Switch
B+ or VBAT= Battery Voltage
BARO= Barometric Absolute Pressure
KOEO= Key-On Engine-Off
BOO= Brake On / Off
KOER= Key-On Engine-Running
BPS= Brake Pressure Switch
BTU= British Thermal Unit
CAC= Charge Air Cooler
CAN= Controller Area Network
CCA= Cold Cranking Ampere
DTC= Diagnostic Trouble Code
LSD= Low Sulfur Diesel
CKP= Crankshaft Position
MAP= Manifold Absolute Pressure
CMP= Camshaft Position
MAT= Manifold Air Temperature
CO= Carbon Monoxide
COO= Cruise On / Off switch
CPU= Central Processing Unit
CTC= Coolant Temperature Compensation
Cyl= Cylinder
MPR= Main Power Relay
MSDS= Material Safety Data Sheet
DCA= Diesel Coolant Additive
DLC= Data Link Connector
NC= Normally closed (electrical)
DMM= Digital Multimeter
Nm= Newton meter
DOC= Diesel Oxidation Catalyst
NO= Normally Open (electrical)
DPF= Diesel Particulate Filter
NOX= Nitrogen Oxides
EBP= Exhaust Back Pressure
OL = Over Limit
ECM= Electronic Control Module
ECT Engine Coolant Temperature
PID Parameter Identifier
EFP= Engine Fuel Pressure
P/N= Part Number
EG= Ethylene Glycol p
EGDP= Exhaust Gas Differential Pressure
EGR= Exhaust Gas Recirculating
PTO= Power Takeoff
PWM= Pulse Width Modulated
PWR= Power (voltage)
EOP= Engine Oil Pressure
EOT= Engine Oil Temperature
rpm= Revolutions per minute
ESN= Engine Serial Number
SCA= Supplemental Cooling Additive
SIG GRD= Signal Ground
SW= Switch (electrical)
TACH= Tachometer
FRP= Fuel Rail Pressure
TBD= To Be Determined
TDC= Top Dead Center
GND = Ground (electrical)
TCM= Transmission Control Module
ULSD= Ultra Low Sulfur Diesel
UVC = Under Valve Cover
VBAT or B+= Battery Voltage
GPR= Glow Plug Relay
VGT= Variable Geometry Turbocharger
VIGN= Ignition Voltage
VIN= Vehicle Identification Number
VREF= Reference Voltage
HPFP= High-Pressure Fuel Pump
VSS = Vehicle Speed Sensor
WIF= Water In Fuel
Originally Posted by dentexpowerstroke View Post
I've already explained that to him multiple times tho and he doesn't understand... Im about to bust out some crayons and draw it for him.
6637 Filter, Warn locking Hubs, Recon LED Cablights, Leveled 2", 8" CAT Stack, 35" Goodyear Duratracs, High pressure oil crossover tube
mcyrana is offline
post #3 of 9 Old 04-07-2013, 06:04 AM
Quoted: 174 Post(s)
Feedback Score: 3 reviews
I have this, it has some more SD specific stuff (and it's at least alphabetical
4x2 Two Wheel Drive
4R100 auto tranny on SuperDuty trucks 99+
4x4 Four Wheel Drive
4X4L Four by Four Low
6637 the part number of the Wix/Napa 6637 air filter
ABS Antilock Braking System
AC Air Conditioning
ACC - Accessory Position of ignition key
ACC Air Conditioning Clutch
AIC Auxiliary Idle Control (see APCM)
APCM Auxiliary Powertrain Control Module(FORD's name for AIC)
AP Accelerator Position
APS Accelerator Position Sensor
ATF Automatic Transmission Fluid
BARO Barometric Pressure Sensor
BOO Brake On/Off
CC Crew Cab (4 door)
CDR Crankcase Depression Regulator
CLV - Calculated Load Valve
CPS Cam Positioning Sensor
CCV Crank Case Ventilation
DI Direct Injection
DLC Data Link Connector(OBD connection)
DRL Daytime Running Lights
DRW Dual Rear Wheels, dually, Dooley
DTC Diagnostic Trouble Code
DVOM/DVM Digital Volt-Ohm Meter/Digital Volt Meter
E4OD auto tranny on pre-'99 Ford heavy pickups
EB Exhaust Brake
EBP Exhaust Back Pressure
EBPR/EPR Exhaust Back Pressure regulator
EBPS exhaust back pressure sensor
EBV/EBPV Exhaust Backpressure Valve
ECM - Engine Control Module
EEC(M) Electronic Engine Control (Module)
EGR Exhaust Gas Recirculation
EGT Exhaust Gas Temperature
EOT Engine Oil Temperature
EOP Engine Oil Pressure
ESOF Electronic Shift On-The Fly
ESP Extended Service Plan
FICM Fuel Injector Control Module (6.0 term for IDM)
FIPW Fuel Injection Pulse Width
FTVB factory tech valve body
GAWR Gross Axle Weight Rating
GCWR Gross Combined Weight Rating
GEM Generic Electronic Module
GP Glow Plug
GPC Glow Plug Controller
GPR Glow Plug Relay
GVWR Gross Vehicle Weight Rating
GVW Gross Vehicle Weight
GW Gross Weight
HEUI Hydraulic-actuated Electronically-controlled Unit Injector
HPOP High Pressure Oil Pump
HPX or H/X - High Pressure oil crossover mod that connects the two HP oil rails together
IAT Intake Air Temperature
IBC Integrated Brake Controller (Tow Command)
ICP Injection Control Pressure
ICPR Injection Control Pressure Regulator
IDI In Direct Injection
IDM Injector Driver Module
IPR Injection Pressure Regulator
IVS Idle Validation Switch
KOEO Key On Engine Off
KOER Key On Engine Running
LB Long Bed
LS Limited Slip
LWB Long Wheel Base
MAF Mass Air Flow Sensor
MAP Manifold Absolute Pressure Sensor
MIL Malfunction Indicator Lamp
NGS New Generation Star (Ford vehicle diagnostic scan tool)
OASIS On-line Automotive Service Information System
OBD On Board Diagnostics
OD Over Drive
OEM Original Equipment Manufacturer
OTC Overhead Trip Computer
PATS Passive Anti-Theft System
PBA Parking Brake Applied
PCED Powertrain Control/Emissions Diagnosis service manuel
PCM Powertrain Control Module
PCV Positive Crankcase Ventilation
PDL Power Door Locks
PM Power mirrors
PMRs power metal connecting rods
PS Power Steering / Power Stroke
PSD Power Stroke Diesel
PTO Power Take Off
PW Power Windows
PWM Pulse Width Modulation
RABS Rear Anti Brake System
RC Regular Cab
RR regulated return
SB Short Bed
SC Super Cab (extended cab)
SD Super Duty
SRS Supplemental Restraint System (air bags)
SRW Single Rear Wheel
SWB Short Wheel Base
TC Torque Converter or Transfer Case
TCC Torque Converter Clutch
TCIL Transmission Control Indicator Light (OD off)
TCM Transmission Control Module (new for 6.0)
TCS Transmission Control Switch (OD off Button)
TFT Transmission Fluid Temperature
TPS Throttle Position Sensor
Turbo turbocharger
TSB Technical Service Bulletin
VIN Vehicle IdentNumberification
VREF Voltage Reference
VSS Vehicle Speed Sensor
WOT Wide Open Throttle
WW Wicked Wheel
ZF Some Crazy German hand-shaker Transmission
NoRalPh is offline
post #4 of 9 Old 04-07-2013, 06:19 AM
mcyrana's Avatar
hey gimme a break im still drunk from last night haha im lucky i was able to log into my service account to get to those acronyms
mcyrana is offline
post #5 of 9 Old 04-07-2013, 07:59 AM
Quoted: 174 Post(s)
Sorry, didn't mean to blame you for anything!
NoRalPh is offline
post #6 of 9 Old 04-07-2013, 08:01 AM
mcyrana's Avatar
haha I see what you did there!
mcyrana is offline
post #7 of 9 Old 04-07-2013, 09:20 AM Thread Starter
Lunnzz's Avatar
Sweet just what I was looking for I'm gonna save them.
Thanks
Edge programmer
AirRaid intake
4" open exhaust
6" lift
Lunnzz is offline
post #8 of 9 Old 04-11-2013, 09:37 AM
JamieSinns's Avatar
OH, this list is sweet! thanks for the information! now i can educate myself.
JamieSinns is offline
post #9 of 9 Old 04-21-2013, 12:59 PM
thodges89's Avatar
Quoted: 9 Post(s)
Thanks
Not really sure what you're talking about here...do you mean you need an AL? Lol jk man. These lists are GOLD!
Sent from AutoGuide.com App
thodges89 is offline
