Grounded loop and auto enginuity question. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-06-2013, 06:27 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
Okay I have an auto enginuity and a crappy laptop. The battery life on the laptop during the daytime (full screen brightness so you can see) is about 20 minutes. I plan on getting a windows 8 tablet as AE can run of them apparently, but not for a while.
Using a power invertor and charging the laptop off that cigarette lighter while plugged into the PCM is a big no-no because they share a circuit I know that.
My truck also has a "power point" right beside the airbag on/off switch. And I think this is on a different circuit. I know it's on a different fuse.
Am I understanding the grounded loop issue right? I should be able to charge the laptop off that power point, and be plugged into the PCM right?
schlutzer is offline
post #2 of 6 Old 04-07-2013, 01:31 AM
I would say no.
I had a 97 that I tried to run the laptop off a direct tap from the batteries and it had a ground loop issue with that. The only way I can think of not have the ground loop issue is to use a Isolated ground inverter, though I never tried it.
99 F350 CCLB 67k miles.
Sold: 01 Dodge cummins ECLB a few more mods to 353hp
Sold: 97 F250 SCLB, 5 speed 2wd. minor mods to 327hp
See a pattern? next I will have to find one of those 6 door jobbers...
Big Bird is offline
post #3 of 6 Old 04-07-2013, 06:58 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
I remember seeing Burnt Pins in a USB cable when doing this. AE says it's a Big N0-N0 and you can't do it no matter where you pull power from. It's not about something as simple as a ground circuit that's shared with the PCM.
Do you have a Starter Pak? You know, one of those 12v portable jump start batteries? If you kept that charged (how many of us have 1/2 charged starter paks ) and plugged the inverter into that it should last a good, long, time...
NoRalPh is offline
post #4 of 6 Old 04-07-2013, 01:02 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
So basically I would need a third battery, with a circuit on its own.
Windows 8 tablet it is lol
post #5 of 6 Old 04-07-2013, 01:04 PM
Macon's Avatar
Yeah, additional battery would be the way. But, any excuse to get a new toy!
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #6 of 6 Old 04-07-2013, 01:25 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
Actually hang on. As I understand it.
I could run a third battery and have it charged off the alternator, just anything I run off it needs to ground back to the battery itself, not to the body/frame? That would be simple enough. And I have a load of 0/1 sitting around.
