02 power wont turn off - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-06-2013, 05:36 PM Thread Starter
I have an 02 7.3 and when I turn the ignition off the power wont shut off. The radio stays on, the key fob stops working. I have to pull the negative terminals of the batteries to shut it down. The truck runs fine, just wont turn off. The engine turns off but the electric stays on. Any help is appreciated
Motorman98 is offline
post #2 of 15 Old 04-06-2013, 05:39 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Does your dome light come on when you open the drivers door?
dhanna6powerstroke is offline
post #3 of 15 Old 04-06-2013, 05:45 PM Thread Starter
No. I tried a few times and same results. No light till I turn the ignition
post #4 of 15 Old 04-06-2013, 05:48 PM
Mod Newbie
Quoted: 20 Post(s)
If you turn the key off, open the drivers door and the dome light doesn't come on then it sounds like you have a door ajar switch sticking. Try opening the front passenger side door and see of the power turns off or if the dome light comes on.
post #5 of 15 Old 04-06-2013, 05:57 PM
Cool need help knowing how to post a new thread
I just registered today, but I have no idea how to post a new thread. I only know how to reply to existing threads. Can anyone help me out?
fliciaga1 is offline
post #6 of 15 Old 04-06-2013, 05:59 PM
Mod Newbie
Quoted: 20 Post(s)
Go into the sub forum you want and click the blue button at the top left that says "new thread".
post #7 of 15 Old 04-06-2013, 06:26 PM Thread Starter
I tried that and had same results. When I'm driving down the road the open door light stays on even though all doors are tightly closed
post #8 of 15 Old 04-06-2013, 06:31 PM
Mod Newbie
Quoted: 20 Post(s)
Have you tried spraying WD-40 into the door latches and then shutting and opening the doors a few times. Sometimes that helps.
post #9 of 15 Old 04-06-2013, 06:41 PM Thread Starter
I'll give it a shot
post #10 of 15 Old 04-07-2013, 01:05 PM Thread Starter
Gave all of the doors a good soaking with WD40 and still same results.
