Train Horn Wiring Question - Ford Powerstroke Diesel Forum
Old 02-04-2008, 07:21 AM
Hey guys,m
I have a quick question. I was installing my new train horn on an early '99 F-250 last night and I ran into a snag. I want to use my factory horn "button" with a toggle switch so that I can go between my stock horn and my train horn without an additional button.
My question is:
Does anyone know what color the horn wire is on an early '99? I have seen in a couple of previous posts where guys tapped into a yellow wire with a green tracer. Mine is not that color (at least that I can find under the dash). I would really appreciate if someone could give me a hand if you have a wiring diagram or just general knowledge.
I will post pictures / video when I get done.
Thanks!
===Russell
Old 02-04-2008, 07:25 AM
Send a message via AIM to BOILERTURF2387
I'm not sure on the color, but najaf4life did what you are wanting to do with the toggle switch. Shoot him a PM and see if he remembers. GOOD LUCK
Old 02-04-2008, 08:04 AM
just go to the horn and follow the wire back as far as ya can and tap it there..thats what I did..
Old 02-04-2008, 08:56 AM
I would, but it is painful to get to. I was trying to see if anyone already knew what color it was. Thanks!
Old 02-04-2008, 03:50 PM
I found a solid dark blue wire underneath the dash that has 12 volts until the horn is depressed. When you blow the factory horn this wire drops to 0 volts. I am sure this is hooked to the horn relay. Does anyone know if I can use a relay from here to energize the train horn? Any other thoughts?
Thanks!
===Russell
Old 02-04-2008, 04:01 PM
yes the terminal #87 on the horn relay is what i used, just hook your air horn trigger wire to that terminal and install a switch on/off switch, then you can choose either the factory horn or factory with train horns. I think it's relay # 3 in the under dash fusebox
