E99 coolant flush - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-06-2013, 01:43 AM Thread Starter
E99 coolant flush
So I am considering flushing the coolant soon and have been trying to read up on it. I found a few write ups on it and plan to buy the napa coolant flush kit. The one thing I'm not clear on is the type of coolant required for the early 99 engine. I was reading that the early models have different requirements than late 99 and newer. What exactly should I be looking for? Any other tips on this is appreciated.
1999 (early) F250 srw supercab longbed 4x4. automatic transmission.
2005 Harley Davidson Road King. V&H true duals/ monster ovals, PCV tuner, andrews 21 cams
MOSTWANTED is offline
post #2 of 9 Old 04-06-2013, 05:57 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Does the truck have the original injectors?
E99 trucks use a different sealant on the injector cups than the late 99+ and therefore the 2-EHA found in most OAT coolants (like coolants meeting Cat EC-1) can eat the sealant on the cups and cause an injector cup failure.
Now if the truck had its injectors changed there is the possibility they changed the sealant but it is not a sure thing.
For simplicity sake you could get a pre-charged coolant like Fleet Charge or Napa's fleet coolant or you could get some plain old green coolant (meeting ASTM D4985) and add SCA (supplemental coolant additives, designed to fight cavitation aka pitting of the cylinder walls). I like Cummins DCA 4 as an SCA, very effective and you can use less of it compared to a DCA 2 like Napa Kool.
Supplemental Coolant Additives (SCAs)
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #3 of 9 Old 04-06-2013, 06:20 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
What if I have aftermarket injectors? What kind of sealant are you talking about?
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 9 Old 04-06-2013, 06:29 AM
Quoted: 17 Post(s)
I would imagine they would have redone the cups..
here is the "new" sealant, I don't even know if they offer the old stuff anymore.
https://www.fcsdchemicalsandlubrican...nd%20Adhesives
post #5 of 9 Old 04-06-2013, 07:34 AM
timmyboy76's Avatar
if you dont no if the cups were replaced, no sense in "finding" out. Stay with, what will work and be done...green, gold.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 9 Old 04-06-2013, 12:04 PM Thread Starter
I assume they are OEM but no way to know for sure. Would this be the safe route to use a pre charged?
post #7 of 9 Old 04-06-2013, 12:10 PM
Quoted: 17 Post(s)
IMHO yes.
Some have run elc without issue cause not all elcs have 2-eha.
I know a lot of people have a hardon for elc but in a 7.3 green and gold both work well they just require a little more user input.
post #8 of 9 Old 04-12-2013, 09:28 AM
RACERX's Avatar
If it were my truck I would use Fleet guard for the Flush. There's a very detailed Post somewhere on Power stroke on flushing. You should remove the two lower block plugs, the one on the passenger side requires removing the starter. I will see if i can find It. You should add a coolant filter to your rig.
RACERX is offline
post #9 of 9 Old 04-12-2013, 10:08 AM
Quoted: 17 Post(s)
Here you go...
Coolant changing instructions... - Diesel Forum - TheDieselStop.com
Oh if you have a stubby 1/4" drive racket you don't need to remove the starter... it is a tight fit but you can get it in there...
