Make radio stay on after key off - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-05-2013, 06:20 PM Thread Starter
thetechie01's Avatar
I have a '00 Lariat, and I am wondering if anyone knows if there is a way to make the radio stay on after the key is turned off, until the doors are opened? The windows stay operational like that, so I know there is circuitry somewhere for it, but where would I tap into that? I am thinking that I could just run the ACC wire for the radio that turns it on and off to that circuit, wherever that is...
thetechie01 is offline
post #2 of 11 Old 04-05-2013, 06:35 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Why? Just turn the radio off. Not like it'll kill your batteries.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 11 Old 04-05-2013, 06:40 PM Thread Starter
Huh? Right now, it turns on when I turn the key on, and then off when I turn the key off, like normal. A lot of newer cars, the stereo will stay on after you turn the truck off, until you open a door, then it shuts it off, this is what I want to do. I have an aftermarket head unit, and it would be nice to be able to shut the truck off and continue to talk on my phone (thru the Bluetooth) without the stereo shutting off as soon as I shut the truck off.
post #4 of 11 Old 04-05-2013, 06:47 PM
BIG Laing's Avatar
Yes you can make it happen. I don't know what color the wire is, but you have to get the wiring harness for the radio and cut the right wire and plug it into a power source like you mentioned.
BIG Laing is offline
post #5 of 11 Old 04-05-2013, 06:54 PM
PowerstrokinIt F250's Avatar
if you say the windows still go up and down when the truck is off but door isnt open yet, simply splice your radio power wire into the power wire for one of your door's window motors.
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #6 of 11 Old 04-05-2013, 06:57 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Oh I thought you were saying the opposite.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 11 Old 04-05-2013, 07:01 PM Thread Starter
No problem, I was a little confused
post #8 of 11 Old 04-06-2013, 04:36 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
Do you have a circuit, in the fusebox, labeled "Delayed Accessory"? (look in the Owners Manual).
A bunch of electrical revisions were introduced during the '01 MY. Maybe that was one of them,,, that's the delayed accessory though, the delay is in turning the radio Off with a timer (or the door). If the 2000 doesn't have that circuit then I'm sure it's possible to build one and add it to the Radio supply line if you were into that kind of stuff
NoRalPh is offline
post #9 of 11 Old 04-06-2013, 05:47 AM Thread Starter
Perfect, that's the info I was looking for! I found a fuse diagram online (didn't get a manual with my truck) and I see that the relay #5 is marked as "Accessory Delay Relay". Is that what I am looking for? Sounds like it. Thinking I could just find which wire is hot coming off that relay (that also goes dead when the key is off and door opened) and tap into that for the trip wire for the stereo. Sounds simple enough, right? LOL
post #10 of 11 Old 04-06-2013, 06:30 AM
timmyboy76's Avatar
Really!!!...
OP, mine stays on, but its wired that the (+) and acc power, are 1.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
