IPR replacement - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-04-2013, 02:23 PM Thread Starter
blue99stroker's Avatar
Quoted: 258 Post(s)
IPR replacement
so i finally got around to changing my IPR today.
some symptoms ive been having are hard starts when the truck is warmed up, rough idle at a stop, and ive noticed my fuel mileage has been suffering.
it only took about 15 mins to do, and i used a mac tools 1 1/8 socket, i read around that you need a special socket but the mac deep socket worked great.
ive noticed significantly smoother take offs and more power throughout the entire power band. easier starts when truck is warm also
i also noticed atleast 3 more psi of boost, i saw an average of 27-28 psi on my 140 ext tune from php. it spiked once at 30 psi for a second or so.
i have a first gen wicked wheel also.
thought id share my good luck
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #2 of 5 Old 04-04-2013, 07:06 PM
Joel's Avatar
Quoted: 10 Post(s)
I did mine a couple weekends back and also had great results. MPG's went way up, truck is smoother and quieter, more power too.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 5 Old 04-05-2013, 11:29 AM Thread Starter
Quoted: 258 Post(s)
im hoping my mpgs go up!
my truck runs so much smoother its incredible.
i replaced my EBPV sensor too cause it was bad so i hope the combination of those gets me some better mpgs.
post #4 of 5 Old 04-08-2013, 06:55 PM
Eco Taxi's Avatar
im getting ready to do this myself - i got the 1 1/8 socket and the IPR
anything specific about removing it? how much oil leaks out? do you worry about air in the system?
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #5 of 5 Old 04-08-2013, 07:36 PM Thread Starter
Quoted: 258 Post(s)
make sure the socket is deep enough.
its easy, its more pleasant to do this when the truck is cold, cause everything gets hot down there.
put some rags underneath before you pull it out.
i took the sensor out walked away grabbed the new one off the bench and put it in and not a whole lot of oil came out
as far as air goes i didn't worry about it but you could purge it if you wanted to by pulling the icp out i think.
ive already noticed better mpg and better running
