Help! P1211 Code - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-04-2013, 07:57 AM Thread Starter
Help! P1211 Code
I have a 1999 F250 7.3 with 127,000 miles. It's used as my work truck and I had to get on it the other day and a "service engine" light came on. Read the code and P1211 popped up. "Injection Control Pressure (ICP) Not Controllable-Pressure Above/Below Desired". I don't feel like it's running any differently but I have only owned it for about 3 weeks so I don't know the truck that well. Thank you!
argrafton is offline
post #2 of 4 Old 04-04-2013, 08:17 AM
blue99stroker's Avatar
Quoted: 260 Post(s)
this is common on trucks with programmers or chips. the computer calls for oil pressures above what the stock programming uses.
if its all stock i would pull the plug out of the icp and look for oil coming through the sensor.
if theirs oil coming through the sensor its going bad.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 4 Old 04-04-2013, 08:26 AM Thread Starter
Thank you! I will try that today
post #4 of 4 Old 04-04-2013, 10:29 AM
Justin@DP-Tuner's Avatar
Quoted: 57 Post(s)
This could also mean that the HPOP is getting weak. You would need a scan tool to confirm this though.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
