Buying a high mileage 2000 7.3 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-03-2013, 08:11 PM Thread Starter
I'm looking at a 2000 f250 7.3 4x4 with 218k miles, it's had 3 owners and the guy that has it now knew the owner before him. It's pretty much stock but has a chip. It does have a ball in the bed. But only used by last owner to tow his camper. The interior is in great shape too. New turbo and a couple other new parts. What should I look for? And yes I'm taking it to a ford dealership to have them look it over.
Outty1000 is offline
post #2 of 4 Old 04-03-2013, 11:48 PM
444 ci's Avatar
oil pan rust, blow by,oil in the coolent or coolent or diesel fuel in the oil
444 ci is offline
post #3 of 4 Old 04-04-2013, 01:42 AM
SEVEN THREE's Avatar
Also check for leaks around the High pressure oil pump lines the o rings tend to go bad, also check for leaks around the turbo pedestal, check for leaks around the rear main, check for trans slippage if its 4r100 check the clutch out if its zf6, and check the ball joints, make sure the 4wd works,check for white smoke during a cold start that is a sign of bad gpr or glow plugs or both, check the alternator out meaning look at the battery amperage when you cold start it-it shouldn't fluctuate. Basically it don't be afraid of a lot of owners if it's a good deal these trucks truly are tough as it gets.
:Edit:
Mine gets 13mpg and diesel is more expensive to fill up and maintain these trucks are not cheap and should never be neglected with maintenance so if you truly don't plan on towing you don't need it unless you love them and have $ to burn, have fun!
Currently Own:
Red 1997 Powerstroke 4x4 regular cab heavy duty zf5 manual-some mods.
White/Gold 2001 Powerstroke 4x4 Extended cab shortbed Lariat 4r100-more mods.
_____
Green 1995 Powerstroke 4x4 regular cab zf5-some mods (SOLD)
SEVEN THREE is offline
post #4 of 4 Old 04-04-2013, 05:41 AM Thread Starter
Thanks guys. I've heard about the oil pan.. And should it have no blow by or is a little fine?
