How to install 2008 taillights on your 99-07 SD - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-03-2013, 05:13 PM Thread Starter
mcyrana's Avatar
I took a look and didnt really see any write ups explaining how to do it so im going to write one up.
First remove the old taillights by removing the two 8mm screws, Then pull on the taillight to free it from the clips. *note* sometimes they like to stick so when pulling be ready for a sudden release.
You are also going to need to buy 2 new light sockets because the new taillights will have smaller holes and the stock 99-07 are too big. you can get the parts at autozone Dorman Part #85814 I also recomend buying the 922 lightbulbs since they are much brighter
Next you have to take the sockets and cut down 3 of the tabs on the side. they will not fit unless you do so. you do not need to cut off alot, If you have trouble getting them to twist in bend the base of the socket up a little to give the tabs more room to fit into the taillight
Cut the old reverse light socket off and expose the wires on the new socket and on the wires coming from the truck
You can connect the wires however you feel by soldering using butt splices ect. polarity is not an issue. I chose to use solder and shrink wrap for durability
After that install the socket into the taillight and install! the new taillights will be a perfect fit and should not give you any issues going back in. Make sure the 4 tabs on the taillight line up with the holes in the truck.
Enjoy your new taillights
Originally Posted by dentexpowerstroke View Post
I've already explained that to him multiple times tho and he doesn't understand... Im about to bust out some crayons and draw it for him.
6637 Filter, Warn locking Hubs, Recon LED Cablights, Leveled 2", 8" CAT Stack, 35" Goodyear Duratracs, High pressure oil crossover tube
mcyrana is offline
post #2 of 5 Old 04-03-2013, 07:13 PM
Joel's Avatar
Quoted: 10 Post(s)
Good job, thanks for taking the time to do a write up.
This should be added to the 7.3 tech section for reference.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 5 Old 04-03-2013, 07:41 PM
Koda22's Avatar
Quoted: 5 Post(s)
Good right up, is there any light benefit to doing this or is it just looks?
Koda22 is offline
post #4 of 5 Old 04-03-2013, 10:09 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
People usually do it because it looks a lot better. I have heard some say that the reverse lights work better on the newer tail lights as well.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #5 of 5 Old 04-05-2013, 11:18 AM
Quickhorse's Avatar
The reverse lights work better and there is a pre-drilled spot on the taillights that has a sticker over it where you can put a strobe bulb. I bought the sockets from Ford and didn't have to cut anything. The lights themselves don't sit in the bed quite the same but they look ten times better than any aftermarket or OE taillight from our year trucks.
I've been using them for a couple years now with strobes and no problems.
Just be carefull not to strip the plastic threads when installing them.
2008 F350 CCSB FX4 Amsoil fluids, S&B intake, 5" exhaust, Egr delete, Boss V plow, Mega Duty Title mod.
Quickhorse is offline
