DIY Intake Question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-01-2008, 01:31 PM Thread Starter
Other vehicle is an F250
Hank's Avatar
DIY Intake Question
I've got all the stuff I need to do the Tymar mod. Looked under the hood at lunch and noticed that the air intake box seems to be part of the battery box cover. I have a 6" lift and was on my tip toes. Did I see this wrong? The help pics on here show an exposed battery after the installation. Is there anything I should know before I tear into this project? Thanks.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #2 of 11 Old 02-01-2008, 01:35 PM
pinkfloyd's Avatar
Send a message via MSN to pinkfloyd
the air box is actually a seperate piece, there are tabs that connect it to the battery cover. Take out the screws in the bottom of the air box and push in the tabs and it will come out.
2002 f-250 4X4 XLT 7.3,
stock tranny
DP-Tuner F6 chip
mbrp ss 4" turbo back exhaust
diy intake with zoodad mod
3 pilllar guage setup with autometer guages Thanks Raul
valve body
boost fooler
NEXT ON LIST
torque converter
pinkfloyd is offline
post #3 of 11 Old 02-01-2008, 01:48 PM
pinkfloyd's Avatar
you got a pm
stock tranny
DP-Tuner F6 chip
valve body
boost fooler
NEXT ON LIST
torque converter
post #4 of 11 Old 02-01-2008, 01:55 PM Thread Starter
Hank's Avatar
Thanks
(Not sure what is going on with my thread. Your PM was just your profile. I finally pushed a few buttons and got it so I can view your replies.)
Thanks for the info. I live a good haul from the nearest anything, and didn't want to have to figure out a way to get back to town after I started tearing down the box. I haven't looked at it real close yet. Got the filter, clamps, pipe and ladder. May try the zoodad this weekend too.
Thanks again.
Hank is offline
post #5 of 11 Old 02-01-2008, 01:58 PM
pinkfloyd's Avatar
I'm sure you'll like it.
stock tranny
DP-Tuner F6 chip
valve body
boost fooler
NEXT ON LIST
torque converter
post #6 of 11 Old 02-01-2008, 02:09 PM
strokerboy73's Avatar
Thanks again.
the zoodad is real easy. So is the tymar. Once they are done you will notice the difference. And since you are doing the tymar intake, have you thought about doing the Crank Case Vent (CCV) mod? It pretty simple too. Here is a link to some DIY mods. Powerstroke Mods and Maintenance Let us know if you need any help.
-2003 7.3L Powerstr
ke, 4x4, Crew Cab, 170K Miles
"The Last Of A Dying Breed."
-Banks 6 Gun -Straight Piped
-Zoodad Mod -DIY Intake -CCV Mod
-B&W Turnover Ball -Prodigy Brake Contoller
Future Mods:
-4 into 5 in. Turbo Back Exhaust. 6 in. Tip
-Custom Front Bumper
strokerboy73 is offline
post #7 of 11 Old 02-01-2008, 02:36 PM
Yeah, just remove the airbox itself... the lid, and lower box.... ... leave the rest in there... the filter DOES fit...
And, if you have ANY sort of dexterity, and patience.. work the hose, it WILL be forced over the mouth of the filter, took me about 3 or 4 minutes...
Chase
99.5 4R, 4wd, S/C, S/B, Leveling Kit, 315s
4" DP, straight pipe, Gauges, TWildman 6pos. Flipper Chipper
A wise man once said nitrous is like a hot chick with a STD...
You know you wanna hit it, but, you're affraid of the outcome.
:burnout
chasespeed is offline
post #8 of 11 Old 02-01-2008, 04:10 PM
Chase
Did the same thing. Wasnt too bad. Fits better with what i did.
-2003 7.3L Powerstr
Future Mods:
post #9 of 11 Old 02-01-2008, 04:16 PM Thread Starter
Hank's Avatar
Thanks guys
I plan to start with the first light in the morning....ok maybe after the frost melts.....
Hank is offline
post #10 of 11 Old 02-02-2008, 08:38 AM
03_Turbo7.3's Avatar
I just completed this mod of my 03 7.3 and what a noise it makes when you take your foot out of it..my buddy was scared his car was going to be sucked off the driveway lol..i like the mod ill see what it does for MPG when i fill next
03_Turbo7.3 is offline
