GDS fuel spring upgrade - Ford Powerstroke Diesel Forum
Old 02-01-2008, 09:31 AM
what do you guyies think worth it of not Item number: 290201490276 got it off ebay
Old 02-01-2008, 09:37 AM
IU Hoosier Fan
well I am not for sure but here is a link for every one to click on.... it sounds like that could do a little good.. but how much not forsure..
eBay Motors: 99-03 FORD POWERSTROKE TURBO/ GDS FUEL SPRING UPGRADE (item 290201490276 end time Feb-01-08 06:38:14 PST)
Old 02-01-2008, 10:00 AM
why not use a BB
Matt
Old 02-01-2008, 10:02 AM
IU Hoosier Fan
i've heard of people doing that but does it really work? and does it ever hurt it in any way with using a BB?
Old 02-01-2008, 10:03 AM
u see how that new spring is longer thats all the BB does its a spacer. I have seen it done
Matt
Old 02-01-2008, 10:05 AM
IU Hoosier Fan
I understand that it is used as a spacer just wondering how long it holds up to compared to getting the larger spring..
Old 02-01-2008, 10:18 AM
i would try BB and put a gauge on all u would have is time in it fi u wanted to try a spring go for it
Matt
Old 02-01-2008, 12:43 PM
John Wood Nut Swinger
I put my shim in my FPR around 2001. It was making 73psi at that time. When I removed the fuel bowl three months ago it was making 69psi. Does the shim work? YES, at least it did in my test truck for the last 5+ years. Does the factory spring last? YES, at least according my personal testing over the last 5+ years. Does the spring fail prematurely due to the BB/shim? Not that I have herd of on line or in the last 5+ years of my testing.
You will have to make a decision to try the free shim or buy the $20 spring. There are a lot of shimmed FPR's out there however I have only herd of a few that run the GDS spring.
