Better milage wanted
That is a very good place to start. You really should have all of that done before you run a tuner anyway.
Definatly start with the air intake and exhaust first. Have you consisered inflating your tires with nitrogen? Nitrogen is more stable than regular air, and wont exband at high temps. from driving. I havent done it myself, but have several friends that have. They claim to have picked up a couple miles to the gallon. Theres a local tire shop here, that will deflate, and inflate with nitrogen for $20.00. They say gain of 2-3% can be seen. It aint much, but the way diesel prices are... every little bit helps.
Nitrogen is nice to have over a period of time since air fluctuates with heat and cold in the atmosphere. Also too, I invested in a tonneau cover for mine and that jumped my gas mileage immensely! So take that into consideration as you will definitely see an increase |
When I got my 97 OBS I would get about 14MPG. After a chip I only got 15 MPG. With the exhaust up grade it jumped to 17MPG.
So the exhaust is the best way to go, followed by an intake, then chip(with gauges of course). Personally, I don't buy the Nitrogen. Unless you want to be lazy and not check your tire pressure. |
i moded my truck for better mpg and i didnt improve mileage but power!
Cleaning the Exhaust Back Pressure (EBP) Sensor and Tube helped my truck a lot in the power department and most likely mileage also (haven't checked yet). It's not difficult at all.
Guzzle's page shows how: Welcome to guzzle's Ford PSD Maintenance Web Page I don't know much about these intakes, but I ordered a Donaldson Intake Kit because you increase filtering efficiency but still increase airflow whereas I think a lot of these kits don't filter as well. When I put it on, I am going to do the Zoodad mod as well where you cut a hole in the radiator support to get fresh air from outside of the engine compartment and with less restriction. Seems like, on the '99's, you need a little different kit or a special piece for the Donaldson filter kit and they do state on the flyer that it is for '99's built after 1-99. Last edited by bob00stroke; 02-01-2008 at 08:24 AM. |
Thanks for the info ,much appreciated Scott
