super chip 1855 question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-02-2013, 09:49 AM Thread Starter
Duster's Avatar
Super chip 1855 i just put on my 99 super duty and in first gear it only boosts to 17... and in 3rd it will boost 24...
I have the diy air filter, straight pipe exhaust. idm 140, wicked wheel...
How much can you actually do with a superchip 1855??? And how can i get more boost.?
thanks
Duster is offline
post #2 of 9 Old 04-02-2013, 10:13 AM
Mitch
thebierguy's Avatar
Quoted: 85 Post(s)
24 is pretty high for a stock turbo- that is what I get a WOT. I read some where once that anything over that is excess boost and you don't want to see over 29-30 - could be wrong because I read about that probably 2 years ago.
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #3 of 9 Old 04-02-2013, 11:05 AM
Macon's Avatar
24 is the standard safe max with a stock turbo. If you want more, you can trick it to give more, but you'll be spending $1k+ on a new turbo sooner rather than later. The better options are to get a WWgen2 wheel, or a bigger turbo, like the 38r.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 9 Old 04-02-2013, 12:50 PM Thread Starter
Duster's Avatar
I just want a little more out of my truck... Just doesn't go like i want it to.... Does anyone know the full potential of the superchip 1855???? other adjustments???
and is there a boost fooler built into it?
Duster is offline
post #5 of 9 Old 04-02-2013, 01:01 PM
Mitch
thebierguy's Avatar
Quoted: 85 Post(s)
If you want a little more, get rid of the superchips and get a custom tuned chip the likes of Tony Wildman, PHP, DP Tuner, etc. I recommend PHP. Bill does some good work. I had a superchips programmer and decided to go PHP. The truck really woke up after that. Plus the custom tuners are easier on the trannies than the can tunes that superchips puts out.
Mitch
post #6 of 9 Old 04-02-2013, 02:24 PM Thread Starter
Duster's Avatar
MY trans is good to go.. Its new about 50 miles ago. and its built to take whatever I put too it......
Still looking for more people who have used the 1855 for there thoughts
Duster is offline
post #7 of 9 Old 04-04-2013, 09:30 AM Thread Starter
Duster's Avatar
I was realy looking for more info from other guys running the 1855 superchip.....
Duster is offline
post #8 of 9 Old 04-05-2013, 12:25 AM
Quoted: 727 Post(s)
For an off the shelf programmer what you have is pretty good. I had the 1705 model and was very happy with it but I wanted more. Brian at BTS highly recommends superchips against other programmers of that type. He says their shift points and pressures are second to none. Even the custom tuners are not as good unless they copy. Obviously, this is for the E4OD/4R100 trans. I can't say for the others.
Corey@CNCFAB is online now
post #9 of 9 Old 04-05-2013, 12:39 AM
Rodslinger's B1TCH
more boost doesn't translate to more power. boost helps to completely burn the fuel being pumped into the engine. more fuel=more power on a diesel as long as enough air can be forced into it to allow that extra fuel to be completely burned up.
super chip, edge tuners etc. are an entry level plug and play kind of thing. it does what it says and that's the end of it.
sell the superchip and get a custom tune or 6 position chip of some kind.
steve604 is offline
