What to do next: TW Tunes or a FRx - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-02-2013, 05:26 AM Thread Starter
jdereu's Avatar
Debating on what to do next have my chipped reburned from TW or do a FRx from Riffraff. Any opinions?
2000 Ford F-250, Crew Cab Long Bed 4x4, Automatic Transmission, Ts 6 Position, 4" MBRP Exhaust, DIY Intake, Pillar Guages, CCV Mod
jdereu is offline
post #2 of 10 Old 04-02-2013, 06:40 AM
7.3550Duty's Avatar
Get the custom tunes done, will be much happier. Then do a complete Regulated return system. Its only a few more dollars for the complete system.
Robert
01 F350 CCSB
a few mods
7.3550Duty is offline
post #3 of 10 Old 04-02-2013, 08:40 AM Thread Starter
jdereu's Avatar
Where is the best place to get a RR
jdereu is offline
post #4 of 10 Old 04-02-2013, 09:20 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Strictly has the best....we sell them. I would get the complete kit with fuel bowl delete and the post filter.
CT Performance, Inc. is offline
post #5 of 10 Old 04-02-2013, 10:09 AM
Quoted: 3 Post(s)
I have a used frx Ill sell you cheap, you would need one piece for it though because I messed up the threads on removal.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #6 of 10 Old 04-02-2013, 11:23 AM Thread Starter
jdereu's Avatar
Can someone explain to me the difference between a RR and FRx please
Campbellflage I sent you a pm
jdereu is offline
post #7 of 10 Old 04-02-2013, 11:32 AM
Justin@DP-Tuner's Avatar
Quoted: 61 Post(s)
A full RR uses an adjustable regulator and bigger lines to get more fuel flowing and returning to the tank. The FRx just lets the fuel have a route back to the tank using a regulator housing.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #8 of 10 Old 04-03-2013, 06:35 AM Thread Starter
jdereu's Avatar
So what's the major benefits of both of them. What does fuel going back to the tank allow to happen
jdereu is offline
post #9 of 10 Old 04-03-2013, 12:32 PM
Quoted: 61 Post(s)
Fuel going back to the tank will allow air in the fuel rails an alternative route to escape instead of being forced through the injectors. This will increase injector life and quiet down the engine some.
The major benefit to both of them is that they will stop the #8 injector's starvation of fuel. Since #6 fires right before #8, with a stock fuel system the #8 injector does not get the fuel supply it needs because the fuel rail is a dead end design that ends at that injector. Letting fuel flow freely through the rails is what ends this issue.
The main benefit of the full regulated return is the bigger lines used. This lets more fuel flow.
DP-Tuner
Like us on
Justin Bochmann
post #10 of 10 Old 04-03-2013, 12:36 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
RR=for all out power/dragster, my $.02 I'd do the FRx kinda a RR and simple to install I did two on diffrent trucks only takes an hr or less...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
