injectors
i have no oil coming out of the injectors on the drivers side
can anybody HELP me in the right direction |
the UVC is probably bad. check the plug on the inside of the vavle cover and make sure it is clean and plugged in tight. common problem on these trucks.
good luck |
what do you mean uvc
i meant uvc harness (under valve cover harness). the wires for the injectors and glow plugs go through the valve cover. there is a plug on the inside that is known for coming unpluged or partially unpluged. in my case it was only a check engine light and one glow plug not getting power but they can come all the way unplugged and you will loose all the injectors on one side of the motor. thats my only guess
any codes? |
