Oil leak burning oil?? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-01-2013, 07:21 PM Thread Starter
Psd171's Avatar
I'm 17 and just purchased my first diesel 96 7.3. No mods just straight pipe. And I changed the oil right off. (And holy **** it takes a lot of oil). And I noticed that it was low pretty fast. But I have not noticed any puddles. So I heard hpop lines and that gasket ar common to leak. Oh and I should say there is no oil on the oil pan or the back of the motor but ther is oil on the front cover. My goal is to fix this right off and get it reliable before any other goodies. Any advice would be great I'm new to this and just trying to learn.
Psd171 is offline
post #2 of 7 Old 04-01-2013, 07:48 PM
Justin@DP-Tuner's Avatar
Quoted: 51 Post(s)
You may want to check around the oil cooler. That is a common place to leak as well.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 7 Old 04-01-2013, 08:10 PM Thread Starter
Psd171's Avatar
this may also be dumb but what if its burning oil will there be white smoke or not neccicarily?
Psd171 is offline
post #4 of 7 Old 04-01-2013, 08:22 PM
Quoted: 51 Post(s)
If it is burning oil you will blueish/gray smoke out of the exhaust.
DP-Tuner
Like us on
Justin Bochmann
post #5 of 7 Old 04-02-2013, 03:47 PM
O.I.F. Combat Vet 11B
what are reasons for a truck to burn oil?
2000 f250 crew cab 4x4 6sp manual, Jim Rosewood 238/100 hybrids, gtp 38r, srp1.1 hpop, DP-Tuner! Driven diesel fuel sys!
269,xxx and counting!!
ju015dd is offline
post #6 of 7 Old 04-03-2013, 01:13 PM
Quoted: 51 Post(s)
A few ways would be from the turbo, low compression, or injector o-rings.
DP-Tuner
Like us on
Justin Bochmann
post #7 of 7 Old 04-03-2013, 01:15 PM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
or valve guides, or almost any where a o-ring meets oil...or a 07ish and older one can leak fuel at o-ring places too.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
