Up-Pipe Gasket Replacement Instructions? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-01-2013, 06:19 PM Thread Starter
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
My up-pipe donut gaskets have finally statred leaking and I really dont have the extra $$ at this time to buy the IH Up-Pipes. I bought the ford donut gaskets and new bolts. Are there any step by step instructions to just replacing the gaskets?
Thanks
384,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #2 of 9 Old 04-01-2013, 10:55 PM
timmyboy76's Avatar
not really. You'll want to remove the turbo, even though, some people have managed to replace with it in tack. Drop the d/s up pipe and snorkel the p/s and collector out the top..(with turbo removed). Replace the donuts and install with collector and p/s hooked up looseley to collector. Then feed d/s pipe up in and bolt it up giving it some play to re-align turbo to collector. Once aligned, snug turbo up, but not tight, then connect collector to turbo with clamp. Now connect uppipes to manifolds and pipes to collector. The p/s top bolts are a *****. You'll have to use a 1/4in rachet and a swivel to get them bolts. d/s are cake. Once tight, tighten down turbo.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 9 Old 04-02-2013, 06:23 PM Thread Starter
Christ Follower
Quoted: 14 Post(s)
If I remove the turbo, are there any gaskets and seals I need to have before starting?
384,000
PHP Hydra
MBRP 4" Turbo Back
Firestone Ride Rite
Derale Atomic Cool
post #4 of 9 Old 04-02-2013, 06:36 PM
Joel's Avatar
Quoted: 10 Post(s)
Two o-rings
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #5 of 9 Old 04-03-2013, 10:55 AM
timmyboy76's Avatar
might as well, get the other 2 for the motor-pedestal orings.
post #6 of 9 Old 04-03-2013, 08:07 PM
Joel's Avatar
Quoted: 10 Post(s)
Good call.
And since the turbo is coming out anyways, clean up the intercooler pipes, do a ccv mod, foil delete, WW2 install, maybe EBPV delete?
Make a weekend out of it.
Joel is offline
post #7 of 9 Old 04-04-2013, 06:19 PM
If you can pull your down pipe out, it is (to me) a really easy job. I've only done it once and I wouldn't be afraid to tackle it again. I didn't take the turbo out. I took the downpipe out and worked from under the truck. I think the forums make it sound scarier then it is. But be warned, I had to replace my Y pipe/manifold off the turbo because every single bolt broke in it.
It did take an afternoon to do the job. But really, once the pipe is out, you're golden
ABKTM is offline
post #8 of 9 Old 04-04-2013, 10:08 PM
Greenman01 is offline
post #9 of 9 Old 04-05-2013, 07:10 AM
timmyboy76's Avatar
Unless you have an aftermarket exhaust, no way your removing the DP without cutting it, if stock.
