? for those who have done 05+ front axle swap - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-01-2013, 11:05 AM Thread Starter
Quoted: 3 Post(s)
I have looked around at the other threads on it, just wanted to get a consencious from those who have done it.
1. Was it worth it?
2. Is the turning radious/ride noticibly improved?
3. what did it cost/time to complete.
4. Any year that is better to get? 05-07 or 08-10?
I have been looking locally for axles, but I feel like it would almost be better for me to keep an eye out for a rolling chasis. Any info would be appreciated, thanks.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #2 of 6 Old 04-01-2013, 11:09 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
1. Was it worth it?
I have not done this swap, but have been around trucks and cars enough to know that a whole rolling chassis would make the swap so much easier. The rear axle is also diffrent width, you'll need that to make the swap 100% complete, unless you used spacers.
Good luck with the project... I'm on the fence, thought about it, but want to keep my truck's parts interchangeable, and so much changed in '05 that I don't want an 'odd-truck-out' situation. Spare parts like rotors, calipers, pads, etc, which I have on a shelf in the garage.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #3 of 6 Old 04-01-2013, 02:03 PM Thread Starter
Quoted: 3 Post(s)
I can understand that, you have a fleet of them! I am gonna complete my 08 front end conversion first, but wanted to start researching now to see how it worked out for everyone. Thanks for your imput.
2000 DRW CC 7.3
post #4 of 6 Old 04-02-2013, 10:46 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
'08 up best IMO....better brakes larger axles and wider rear WMS..
CT Performance, Inc. is offline
post #5 of 6 Old 04-02-2013, 10:52 AM Thread Starter
Quoted: 3 Post(s)
I guess you would be the one to direct these questions at, Alot of the post I come across are of your doing them on OBS trucks. Whats your thoughts on the swap?
2000 DRW CC 7.3
post #6 of 6 Old 04-02-2013, 11:35 AM
Quoted: 3 Post(s)
I've helped SD guys do this swap also....IMO a great mod if done with a 4 link kit or the ride quality and Castor isn't as good as what can be done with a leaf spring suspension...I've got a set of '10 axles waiting to go into my '03 Excursion...just need some spare time. My stuff is always last.
