Timken 515020 front hub unit install question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-01-2013, 03:30 AM Thread Starter
TTC
About to install a TIMKEN #515020 front wheel bearing hub on my 02 7.3 4x4. Should light grease be used when installing the o-ring to help it seal or does it go on dry?
Thanks.
TTC is offline
post #2 of 10 Old 04-01-2013, 07:03 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
I grease 'em....
Sent from my SCH-I200 using AutoGuide.Com Free App
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #3 of 10 Old 04-01-2013, 07:52 AM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 37 Post(s)
As long as all the surface areas are clean, I wiped my inner down with brake cleaner, then a wipe down with WD-40. It should slide in and seat without any issues - then torque the hub down to the knuckle
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #4 of 10 Old 04-01-2013, 09:56 AM
Quoted: 23 Post(s)
Going together is one thing... coming apart in 5 years after they went together clean, and all that clean metal rusted, diffrent story. I'd grease them, not thick, just a coating, so when you replace the next one, it comes apart easy. Just my 2 cents...
Greg
Semper Paratus
post #5 of 10 Old 04-01-2013, 11:01 AM Thread Starter
TTC
Are the needle bearings pre-greased from TIMKEN also?
TTC is offline
post #6 of 10 Old 04-01-2013, 12:19 PM
AzPatMan's Avatar
Quoted: 37 Post(s)
Yes, you should not have to pre-grease anything.
AzPatMan is offline
post #7 of 10 Old 09-09-2013, 05:20 PM
Tempsho's Avatar
Quoted: 3 Post(s)
I just ordered a set of timken wheel bearings for my truck to.
Does anybody the torque for the studs holding the hub assembly to the axle?
2002 7.3L Excursion Limited 4x4
- 21"/11"/21" Vision X Xmitter Prime light bars (47,000 lumens)
- Edge CS Monitor
- Tymar intake
- Fumoto Quick Drain Valve
- Coolant filter, ELC, 203* T-stat and billet housing
- Riff Raff boots
- PHP Chip (Stock, 80DD, 100Race, Whisper Mode, 80Tow, Smoke Show)
- F350 leafs front and back
- Hellwig rear sway bar, Bilstein 5100's
- LT275/65R20 Durtrac's on 20" King Ranch wheels
- Fred Goeske 2" steel wheel adapters
- Genuine Larry B's Denso starter
Tempsho is offline
post #8 of 10 Old 09-10-2013, 06:51 AM
AzPatMan's Avatar
Quoted: 37 Post(s)
Keep in mind - those are 'studs'.
Just run them in - and another 1/4 turn (and no more.)
All your clamping force will be by the nuts which you torque on.
AzPatMan is offline
post #9 of 10 Old 09-10-2013, 09:47 AM
Tempsho's Avatar
Quoted: 3 Post(s)
Yeah, I realize they are studs. I guess the proper question to ask would be whats the torque for the nuts!
- Edge CS Monitor
- Tymar intake
- Riff Raff boots
Tempsho is offline
post #10 of 10 Old 09-10-2013, 10:07 AM
AzPatMan's Avatar
Quoted: 37 Post(s)
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Gonna require some muscle.
133ft-lbs.
AzPatMan is offline
