bpd tech step - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-31-2013, 05:08 PM Thread Starter
Quoted: 16 Post(s)
Feedback Score: 3 reviews
bpd tech step
anyone have one? looks like it would be handy but the cost? anything out there similar but cheaper? been using the milk crate but i'm tired of the two year old pulling it out from under me.
BPD Tech Step
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #2 of 5 Old 03-31-2013, 05:15 PM
JD3020's Avatar
Why not build something out of some 2x4's, plywood, and a couple hinges? It'd be dirt cheap, make it any size you want, and did i mention it'd be dirt cheap? I'm going to build me one shortly, although i may try to make it small enough to fit in between the front of my toolbox and the bed.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #3 of 5 Old 04-01-2013, 03:13 PM
heisman01's Avatar
Quoted: 52 Post(s)
I could build that out of about 20 bucks worth of steel...
heisman01 is offline
post #4 of 5 Old 04-02-2013, 04:54 AM Thread Starter
Quoted: 16 Post(s)
i'll take one
my welder and stuff are in storage while i build my house, so my fab days are over for a little while
post #5 of 5 Old 04-02-2013, 12:01 PM
Slacker
Evil Eye's Avatar
Quoted: 208 Post(s)
Feedback Score: 4 reviews
I have one and it's awesome. It's one of those things that you don't know what you are missing until you have it... I use it for anything that takes longer than 5 minutes under the hood and it's MUCH better than the stool I would stand on and would fall out from under me when I would go to reach for something in the back. It was invaluable in my turbo swap and when doing standard maintenance.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is online now
