Cold natured? - Ford Powerstroke Diesel Forum
Old 01-29-2008, 12:29 PM
Cold natured?
Not really a problem, so it's not posted there. Just a general question.
My temp gage will go no higher than a little past the cold mark. The tailpipe gets too hot to touch, which is normal, and the truck runs fine. Just wonderding, without having another 444 to compare to, if this is normal or if I have a colder range thermostat than recommended. Are temp sensors prone to fail?
Old 01-29-2008, 01:14 PM
mine gets to about 1/4 when not towing. i noticed you have the blue cps, did you notice any difference with it?
Old 01-29-2008, 04:37 PM
My temp Gauge has always run dead in the middle of the gauge when warmed up, I would think something is not right with your gauge/sender. If you have access to a laser thermometer (there not that expensive) you could shoot the coolant lines and see what you get for a temps.
Old 01-30-2008, 01:56 AM
I bought the truck with it installed. I haven't heard of this problem from anyone else with the blue CPS. Any feedback?
