rocker arm pedestal torque - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-29-2013, 08:27 PM Thread Starter
hi what is the correct procedure for checking and re torquing the rocker pedestal bolts? is simply straight forward or is there more to it ?
lght1 is offline
post #2 of 10 Old 03-29-2013, 09:42 PM
Justin@DP-Tuner's Avatar
Quoted: 51 Post(s)
There is no torquing sequence because there are only two bolts per rocker arm. The correct torque value is 20 ft. lbs.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 10 Old 03-29-2013, 09:44 PM Thread Starter
hi i was concerned that there may be an issue of where the valves are in their travel...
lght1 is offline
post #4 of 10 Old 03-29-2013, 09:56 PM
Quoted: 51 Post(s)
Nope. You are just tightening the rocker arm pedestal down, not doing anything to the valves.
DP-Tuner
Like us on
Justin Bochmann
post #5 of 10 Old 03-29-2013, 10:04 PM
99powerstroke62's Avatar
Quoted: 56 Post(s)
It's good practice to torque em down with the cylinder at TDC of the compression stroke. That way the valves are fully seated and no stress is on the rocker. But as Justin said, its not going to effect anything if your just checking them.
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #6 of 10 Old 03-29-2013, 10:13 PM Thread Starter
hi i was thinking that. i had the v-cover off a week ago and checked the driver's side. one thing i am worried about is that the torque wrench slipped its setting from 20 to about 25 ft lbs or a bit less. do i need to loosen these and re-do? i
lght1 is offline
post #7 of 10 Old 03-29-2013, 11:01 PM
Quoted: 56 Post(s)
I'd loosen em and re torque just for safe measures
Tyler
post #8 of 10 Old 03-29-2013, 11:05 PM Thread Starter
hi do i need to be concerned about tdc when loosing and re-torquing to 20 ?
lght1 is offline
post #9 of 10 Old 03-29-2013, 11:20 PM
Quoted: 56 Post(s)
You should be fine. You won't have to back them off all that much
Tyler
post #10 of 10 Old 03-29-2013, 11:21 PM Thread Starter
its primarily #2 and 4. thanks for the input.
lght1 is offline
