Need help with my 01 7.3 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-29-2013, 12:29 PM Thread Starter
hi guys
so i bought a truck from a guy that said every thing was good n found out that it looses power after 5min of driving .
starts fine n ides good for hours but when driving it looses power n starts to smoke n barely moves n starts knocking hard .
was told by that guy that it needs a fuel pick up replaced n i did n also cleaned the tank and blew the lines ,put new filter but same thing.
took it to a guy called diesel mechanic n he said all injectors n harness r good but made me replace the turbo coz the other one was bad n still same thing happens (u hold the rpm to 3k n it comes down after few min n truck gets messed-up)
bought the damn thing n didnt drive yet n really need help getting it fixed .
it's a 200n one ford f550 7.3 that cannot pu it self
thanks a lot
ghazigo is offline
post #2 of 5 Old 03-29-2013, 12:31 PM
JBRIXEN's Avatar
do you have a way to monitor ICP pressure and duty cycle?
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #3 of 5 Old 03-29-2013, 12:34 PM Thread Starter
No I don't n don't know if he does too . Can u explain to me what to do n ill ask him .
ghazigo is offline
post #4 of 5 Old 03-29-2013, 12:51 PM
JBRIXEN's Avatar
sounds like the coil in the IPR valve is getting weak when warm and not holding pressure. need a scan tool to monitor these.
JBRIXEN is offline
post #5 of 5 Old 03-29-2013, 03:56 PM Thread Starter
Ok
Can I put one from an f250 n c if that fixes it ?
Ill try the ipr first?
Truck only has 129 k miles n a manual transmission n too big to tow coz its a crew can n a 10 ft bed
ghazigo is offline
