Looking to buy - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-29-2013, 05:50 AM Thread Starter
Looking to buy
I'm looking at a 2000 F250 extended Cab 7.3 4x4 with 190,000 miles that's been superchip. What should I know before buying and what should I look at to make sure is not a dog?
Kknight is offline
post #2 of 5 Old 03-29-2013, 06:12 AM
Other than the usual used car stuff to look for, check for a rusty oil pan. Only way to change it is to pull the motor or have someone do it for $1000 or more.
Maintenance records and a cargax are very handy as well. If it was taken care of and not rusty then buy it. For a good price of course.
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #3 of 5 Old 03-31-2013, 02:57 PM Thread Starter
Thanks I'll check all that.
Kknight is offline
post #4 of 5 Old 03-31-2013, 03:16 PM
Macon's Avatar
Check all the bushings on the front end. It's not a deal breaker if they need replaced, but it is a negotiation factor. Mine were good, so I couldn't tell you cost to replace.
Probably the biggest thing to look for is oil in the valley. It won't tell you how well it's been maintained, but it will tell you that you're leaking oil (likely from the HPOP), and you're going to need to do some work to it. Check what air filter he has. If it's a K&N or other "high flow" filter, pull the tube and look at the turbo vanes. Again, not a deal breaker, but you're looking at a minimal of a few hundred for a new wheel or $1K+ for a new turbo if the vanes are ate up.
Those are the quick and easy things to check out. If the owner doesn't want you pulling the intake tube to look at the turbo, bid him farewell. He'll change his tune, or you'll have saved yourself a headache.
*ETA, I was in your same shoes last May. This forum helped me out considerably, and my knowledge base has done nothing but improve from here (and elsewhere of course, but the info found here is either sound, or corrected to be sound).
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #5 of 5 Old 03-31-2013, 04:36 PM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
NoRalPh is offline
