Backup sensor problem, need help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-28-2013, 05:28 PM Thread Starter
belz's Avatar
Quoted: 68 Post(s)
My backup sensors seem to work but every so often when I put it in reverse, it just gives me the solid beep and wont shut off, or it will stop for a second then go back to solid beep. other times it works just fine. the light never comes on that they are off. Could it be a bad sensor?
Belz
CPA Director
belz is offline
post #2 of 8 Old 03-28-2013, 06:08 PM
Term3's Avatar
No, not yet anyway, but soon. That's the way mine were before they died.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 8 Old 03-28-2013, 06:09 PM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
Sounds like a faulty sensor. I haven't messed with OEM systems, but i've installed dozens of aftermarket reverse sensors (service trucks) and when this happens, our way of diagnosing it is to disconnect one sensor at a time and activate the system. If it still malfunctions, you plug it back in and move to the next. When it works correctly, you've found your bad sensor. For some silly reason, it is not uncommon for them to die in pairs, so if following my method doesn't work, unplug two at a time until you locate the bad pair. Its usually just one though.
Originally Posted by ChiefRocka View Post
Great truck, but ugly and I felt like I was driving a penis down the road .....
wvrrcarknocker is offline
post #4 of 8 Old 03-28-2013, 06:11 PM
Term3's Avatar
Yes that's how mine were. The two outside ones were dead.
Term3 is offline
post #5 of 8 Old 03-28-2013, 06:16 PM Thread Starter
belz's Avatar
Quoted: 68 Post(s)
thanks guys. Guess I'll order a pair of sensors.
Belz
CPA Director
belz is offline
post #6 of 8 Old 03-28-2013, 06:44 PM
RedneckYankee's Avatar
If you have AE or know someone that does you can test the system and find which sensor is bad. Moisture can affect the sensor (car wash / hard rain) good luck with it.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #7 of 8 Old 03-28-2013, 06:48 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I know this may sound simpley stupid but have you cleaned off the sensor (mud snow dust dirt dead cat)? I have found these sensors to be next to worthless on my work truck. Justy a little trash and they are all done...
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 8 Old 03-29-2013, 05:37 AM Thread Starter
belz's Avatar
Quoted: 68 Post(s)
Yeah, they are clean.
Belz
CPA Director
belz is offline
