coolant confusion - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-27-2008, 10:15 AM Thread Starter
99bigred's Avatar
coolant confusion
what is the best coolant for an early 99? what type of maintence do you have to do on the coolant? If we do decide to get a coolant filter, should i get it with or without the additives?
thanks
early 99 f-350 7.3 6speed crew cab
banks exhaust, chip, big head, exhaust houseing
and wheel
Ford AIS intake
5.5" fabtech lift w/ 35x12.50/18's
99bigred is offline
post #2 of 5 Old 01-27-2008, 11:46 AM
ns954's Avatar
Check you driver side valve cover for the mfg. date and serial number.If your engine was made after 2/2/99 with a serial number higher than 940614 then an Extended Life Coolant (Red in color) such as Fleetrite or Shell Rotella would be the best to use.No need to worry about coolant additives IF you use ELC coolant.If you have to use green coolant,then you WILL need to add a SCA to your coolant.Fleetguard makes the additive as well as the test strips to determine how much you need.The dieselsite.com filter kit is the easy way to go.It comes with everything you need.You can also get a coolant filter from Carquest (Part Number 89019).If you add a coolant filter kit,do not get the filter that contains SCA's.In fact,dieselsite.com does not sell charged filters.
ns954 is offline
post #3 of 5 Old 01-27-2008, 03:55 PM Thread Starter
99bigred's Avatar
my motor was built in 12/98. is the amsoil coolant good in this motor?
thanks
and wheel
Ford AIS intake
99bigred is offline
post #4 of 5 Old 01-28-2008, 01:23 AM
ns954's Avatar
If it is a low silicate formula it should be fine.Just make sure it says low silicate somewhere on the bottle.If not,then the Fleetrite green coolant is low silicate.It's available at your local international dealer.The dealer will also have your Fleetguard SCA and test strips.
ns954 is offline
post #5 of 5 Old 01-28-2008, 05:23 AM
Powerstroke Junkie
NCHornet's Avatar
12/98 Build date should stay with the green. The ELC is only approved for later models by Navistar, no big deal just make sure you buy the additive and check it often.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
