code questions
What kind of code will a autozone or equivalent code reader not pickup, I have a es light but there code reader will not pick it up or erase it. Truck is stalling while driving ive already had new cps (from recall) put in and new fuel filter. And just wondering if there is only a certain code that the reader wont catch. Ford does not open till monday and i kind of need this truck to run. Thanks for thehelp.
![]() ![]() ![]() :c onfused:![]() ![]() ![]() This happened after i installed ts that might not be right for my computer but i removed it and prob is still there??? |
my understanding is the auto zone scanner wont pickup any codes on thes truck Good luck
Its read codes before on it but some reason it wont pick themup
they will pickup some but i think i read idm codes or something like that wont work with "cheap" scanners, really i have almost no idea
good luck |
Sawyer did you say this started happening after the wrong TS chip was put in ??
Yeah thats what i think its the wrong one It seems to work when installed but after like five miles it will shut off. The ts when installed had a water in fuel light and ses but ran fine. ive cleaned the terminals there spotless. then i took it out and the problem is still there.
I would disconnect your batteries and let it sit for a while then reconnect them. This may reset your PCM. You have the stock chip in now right?
Its stock besides the 18k module from defuser (like 10kmod) Since the ts iv had the batteries unhooked do the cables have to touch or do the headlights hav to be on to reset iv heard something like that iv had them unhooked and hasnt done anything(had them unhooked while taking the ts out.
could this be the icp sensor or pcm is fried truck will still start and run but will die when it wants to.
Hmmmm.... i would have thought having the batteries unhooked you wouldn't have these problems. I had heard someone say you can touch the negative wire to the positive post also to clear the PCM but whether it's true or not i have no idea. I've heard nothing about the headlight thing.
