Wipers won't shut off - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-27-2013, 04:11 PM Thread Starter
My wipers have a mind if their own and won't shut off until I either shut the key off or pull the relay under the hood. I changed the multi switch and swapped relays around but noting changes. Any ideas? GEM? Motor?
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #2 of 3 Old 03-27-2013, 04:55 PM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
I'd be thinking GEM, is it possibly wet from the leaking windshield issue we can have?
Also, on an '01, you might have a traditional GEM, or if you have the '02 electrical upgrade (digital OD, Trans Temp Gauge) it's now relocated to behind the Radio and called a VSM (water is no longer an issue)
NoRalPh is offline
post #3 of 3 Old 03-27-2013, 06:23 PM Thread Starter
Nope not 02 style. It's the traditional gem.
The windshield could possibly be the problem. I've had a drop or two come out of the overhead console after a long rain but I figured that was the marker lights. It's got a crack so it'll have to get replaced anyway. Guess ill have to call the stealership ...
I have an extra motor here so I'm going to try thy before I order the gem.
2000 F550 CC 2WD
Schnot is offline
