F450 transfer case? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-26-2013, 08:36 PM Thread Starter
Wilson7397's Avatar
F450 transfer case?
I just picked up a 99 f450 4x4 powerstroke. The transfer case is blown out of it. From what I've read it is a 271F, it shows the same model for the 250 and 350. I assume that they are interchangeable , or are the output shaft flanges different?
Sent from AutoGuide.com App
Wilson7397 is offline
post #2 of 3 Old 03-26-2013, 08:59 PM
JSchuricht's Avatar
The NP271F is a New Process 271 Ford which is the manual shift transfercase used in all 99+ Super Duties. The 273 is the electric version. What you need to watch out for is what transmission the donor vehicle had. A 4R100 auto uses a different input shaft from a ZF6 stick. You can swap the shaft between the two if necessary.
JSchuricht is offline
post #3 of 3 Old 03-26-2013, 09:02 PM Thread Starter
Wilson7397's Avatar
Thanks. I'll call around to some junkyards tomorrow and get a price.
