Horrible Cold Start!!! Please Help!!!! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-26-2013, 08:03 PM Thread Starter
20Kevin02's Avatar
Just did glow plugs and glow plug relay running rotella 15w/40 thinking injectors? Getting ready to do 80hp injectors anyways may this help? Is there something im missing????
Your never too old or too young to enjoy the smell of a diesel in the morning.
20Kevin02 is offline
post #2 of 14 Old 03-26-2013, 08:58 PM
Eco Taxi's Avatar
Same boat here, I'm getting ready to do injectors next because so far I've done:
Glow plugs
Gpr
Both batteries
Alternator
Starter
Fuel filter
... I'd say its CPS, IPR, or injectors on your e d
Most likely injectors
This weekend I'm changing the CPS and IPR
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #3 of 14 Old 03-26-2013, 09:13 PM
how cold is it when you try to start the truck?
99' Powerstroke is offline
post #4 of 14 Old 03-26-2013, 10:41 PM
Rodslinger's B1TCH
i have some bad cold start issues too and i'm discovering that the problem is with thick oil in the injectors causing stiction when cold. i'm running 15w40 rotella and it's looking like that oil is too thick. a lighter viscosity will allow the injectors to work better when the oil is cold.
i just picked up a bucket of 15w40 that i think i am going to return now and try to find some 5w40.
just my thoughts. my glow plugs all test good, i have a white rodgers relay in the truck, i replaced the o-rings recently and the truck runs perfectly when warm. my next step will be a different oil.
steve604 is offline
post #5 of 14 Old 03-27-2013, 08:16 PM Thread Starter
20Kevin02's Avatar
im thinking 10w40 next oil change and not really cold but if i have it pluged in it seems fine. maybe just below 0 degrees but thats not to bad. im gonna take a look at my icp and maybe replace that
post #6 of 14 Old 03-27-2013, 09:10 PM
99powerstroke62's Avatar
Quoted: 56 Post(s)
This should be in the motor section under powertrain. Just saying..
Id do a compression check btw
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #7 of 14 Old 03-27-2013, 10:36 PM
Rodslinger's B1TCH
i've done lots of searching in google in the past few days relating to powerstrokes and rotella 15/40 compared to t6 and i'm sold on the t6. everyone that has actually tried it has never looked back and is flabergasted with the results.
there are a lot of rotella 15w40 users that are too diehard to acknowledge the claims of easy starts, better running all around and longer oil change intervals so they end up beating the other guys down for "buying into the synthetic hype"
i picked up 15 litres of t6 today that is going into my truck this weekend. hella expensive but i am expecting good things.
steve604 is offline
post #8 of 14 Old 03-28-2013, 02:45 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
synthetic oil makes these trucks start so much easier!
ive been running 5w-40 synthetic and its much better in the cold, plus im gonna go longer between oil change intervals.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #9 of 14 Old 03-30-2013, 12:11 AM
Rodslinger's B1TCH
i changed my oil today and put in rotella t6. i'm hoping for good things to happen. i'm leaving the block heater unplugged for a while to see what happens.
it does seem like the engine is running quieter, there used to be a loud tick like an exhaust manifold leaking that i could clearly hear through the firewall while driving. it seems like it has faded away. standing outside of the truck while it's idleing seems to be a little quieter too.
steve604 is offline
post #10 of 14 Old 03-30-2013, 10:26 PM
Rodslinger's B1TCH
i let the truck sit for 24 hours and then started it up. this would usually mean a rough cold idle. i cranked it over without waiting for the glow plugs and it started up smoothly and went straight into high idle mode.
the truck has never done this in the two years i've owned it. it would always take a few seconds to start and then would chug at low idle for about 30 seconds before kicking into high idle.... sometimes. then it would have a definite miss for a few minutes of driving.
i now believe that rotella t is too hard on the injectors. rotella t6 or probably any synthetic 5w40 is the perfect oil.
it is hard to spend $140 on an oil change though but it seems to be well worth it.
steve604 is offline
