00' horn position - Ford Powerstroke Diesel Forum
Old 01-25-2008, 11:35 AM
00' horn position
How do i acess the horn it sounds lie its by the passenger battery but i cant figure out how to get to it what do you have to remove?
Old 01-25-2008, 11:39 AM
IU Hoosier Fan
you are in the right spot but why are you trying to remove it?
Old 01-25-2008, 11:40 AM
I just want to tie into the wires so i can add some cheapo air hornes, By the way love your pickup.
Old 01-25-2008, 11:45 AM
IU Hoosier Fan
well thanks.... you should do something like this.... .... let me see if I can find the what color the positive lead for the horn is...
Old 01-25-2008, 11:50 AM
IU Hoosier Fan
okay well I just looked at my wires and you do have to take out the passenger battery and remove the battery tray to get to the wire.... and the wire that you want to cut and tap into is the yellow wire with the green stripe....
Old 01-25-2008, 11:56 AM
Thnks a bunch ima going to go out and try that now i appreciate the assistance.
Old 01-25-2008, 11:57 AM
IU Hoosier Fan
alright good luck if you need any help or have any questions ask... and if need to be you can call me and I can try to help over the phone...
Old 01-25-2008, 12:05 PM
just tap into the horn relay in the fuse box under the dash #3 relay i think terminal 87. unless you wanna disconnect the factory horn, then just put a on/off switch in the wire to the air horns, that way you have both
Old 01-25-2008, 12:08 PM
IU Hoosier Fan
did you check out my video on how I wired my train horn? no push button for me... i use the steering wheel and still have my truck horn also..
Old 01-25-2008, 12:32 PM
I just removed the battery and tray and no horn then i removed the washer fluid tank and still no horn? im clueless sounds almst behind the light. should i not see the horn and just see the wire.
